I am running into an issue with i.atcorr in pyGRASS:
Atmospheric Correction
MM DD hh.ddd: 3 25 51.06
Center: ( 95.02001 , 23.115005 )
Timestamp: 25 Mar 2011
> LE71340442011084PFS00.toar.1
> LE71340442011084PFS00.surf.1
File "./python-pygrass.py", line 188, in <module>
i.atcorr(input=b, elevation="dem", visibility="vis",
parameters=prm, output=b_out, flags="ra", range=[0,1],
rescale=[0.0,1.0],overwrite=OVR)
File "/usr/local/grass-7.0.svn/etc/python/grass/pygrass/modules/shortcuts.py",
line 49, in __getattr__
return self.cls('%s.%s' % (self.prefix, name.replace('_', '.')))
File "/usr/local/grass-7.0.svn/etc/python/grass/pygrass/modules/interface/module.py",
line 101, in __init__
self.params_list = [Parameter(p) for p in tree.findall("parameter")]
File "/usr/local/grass-7.0.svn/etc/python/grass/pygrass/modules/interface/parameter.py",
line 59, in __init__
diz['default']) if 'default' in diz else None
ValueError: invalid literal for int() with base 10: '0,255'
I am not requesting for [0,255] so it maybe a default set up in
pyGRASS somewhere... or maybe something changed...
Thanks for any help,
Yann
