[GRASS-dev] pygrass: ipdb dependency
it's seems that pygrass depends on ipdb, see
lib/python/pygrass/vector/geometry.py: import ipdb; ipdb.set_trace()
on other places such line is commented out. Is such dependency really needed?
Thanks, Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Hi Martin,
On Sun, Apr 19, 2015 at 10:22 AM, Martin Landa <landa.martin@gmail.com> wrote:
no, it is just for debugging.
In particular the one that is present on geometry.py is acalled only
when an exception from the SQL is raised:
        try:
            cur = self.table.execute(sql.SELECT_WHERE.format(cols=key,
                                                         tname=self.table.name,
                                                         condition=self.cond))
        except:
Because I was trying to catch a bug, therefore the ipdb is imported
only if the sql execution fails, I can easily remove it.
I don't think it is a big issue.
Best regards
Pietro
