On Wed, Nov 30, 2016 at 12:25 PM, Martin Landa <landa.martin@gmail.com> wrote:
is it possible to use progress info when using ParallelModuleQueue?
Something similar to grass.percent(). Eg.
Yes, I think so, if you pass the stderr_=subprocess.PIPE and
stdout_=subprocess.PIPE parameters to the module, then you should be
able to write the current percentage using grass.percent() or
msgr.percent().
2016-11-30 13:00 GMT+01:00 Pietro <peter.zamb@gmail.com>:
msgr.percent().
yes, but then you get progress info for each module separately, right?
Then you need to process stderr/stdout on your own...
Wouldn't make sense to add something like _progress=True. Then module
could call msgr.percent() automatically when it finish.
queue.percent(5, count) # print each 5%
module = Module(..., _run=False, _progress=5)
for ... in ...:
queue.wait()
2016-11-30 13:59 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
2016-11-30 13:29 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
> for ... in ...:
> queue.wait()
another possibility would be to define own function, eg.
def process(i, n, count):
Module(..., _run=True, quiet=True)
msgr.percent(i, n, count)
Maybe you can implement a derivative from the Module class and implement
the required behaviour there?
Similar approach could be useful when for example applying mask and
doing some processing for each scene with multiple bands.
But such function cannot be used together with ParallelModuleQueue. Or
am I wrong? Ma
I am not sure if i understand you correctly. But you can use
the MultiModule[1] class to specify a stack of modules that should be run
in serial order. Several MultiModule objects can be run in parallel by the
ParallelModuleQueue. However, setting a mask in one module will affect all
other modules that are running in parallel as well, since they are running
in the same mapset. Changing the region in each stack is no problem, since
the MultiModule class provides a dedicated region environment that does not
affect other parallel running modules in the same mapset.
