[GRASS-dev] pygrass - r.report
when using pyGRASS, the statement bellow
from grass.pygrass.modules.shortcuts import raster as r
r.report(map = 'r_ndvi', units = 'c,p,h')
produces an error
  File "/home/martin/bin/grass/ndvi.py", line 34, in <module>
  File "/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/pygrass/modules/interface/module.py",
line 342, in __call__
    self.inputs[key].value = val
  File "/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/pygrass/modules/interface/parameter.py",
line 115, in _set_value
    (self.name, self.values))
ValueError: The Parameter <units>, must be one of: ['mi', 'me', 'k',
'a', 'h', 'c', 'p']
Is it a bug in pyGRASS or I am wrong? Thanks, Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Hi Martin,
On Thu, Oct 17, 2013 at 11:34 AM, Martin Landa <landa.martin@gmail.com> wrote:
Thank you for using and testing... :slight_smile:
It is working, at least on my pc. The pygrass Module interface require
tu give a python list if you have a multiple parameter, so your code
should work writing:
r.report(map='r_ndvi', units=['c', 'p', 'h'])
Please, let me know...
Have a nice day.
Pietro
Hi Pietro,
2013/10/17 Pietro <peter.zamb@gmail.com>:
right, sorry for the noise :slight_smile: Martin
ValueError: The Parameter <units>, must be one of: ['mi', 'me', 'k', 'a', 'h', 'c', 'p']
Perhaps If I can change the error string in something more explicit like:
ValueError: The Parameter <units>, must be a python list containing
one of the following values: ['mi', 'me', 'k', 'a', 'h', 'c', 'p']
What do you think?
Pietro
Maybe this is better:
one or more of the following values: ['mi', 'me', 'k', 'a', 'h', 'c', 'p']
Pietro
+1, Martin
+1
Yann
ValueError: The Parameter , must be a python list containing
one or more of the following values: [‘mi’, ‘me’, ‘k’, ‘a’, ‘h’, ‘c’, ‘p’]
+1, Martin
grass-dev mailing list
grass-dev@lists.osgeo.org
