[GRASS-dev] [pygrass] Report #12
What did I do this week?
This week I did a lot of works:
* move the documentation from ReadTheDocs to:
http://www.ing.unitn.it/~zambelli/projects/pygrass in this way I'm
able to use the sphinx automodule to document the API.
* Add more examples and documentation on vector geometry features:
http://www.ing.unitn.it/~zambelli/projects/pygrass/vector.html
* Add a basic support for the vector attributes:
http://www.ing.unitn.it/~zambelli/projects/pygrass/attributes.html
To see the implementation details see the above links. To run the
doctest you need to use the North Carolina mapset, copy and build the
topology, and copy the table attributes from dbf to sqlite and/or
postgresql.
What will I be working on next week?
I will add the write mode to the Vector objects.
Did I meet with any stumbling blocks?
None
Any comment or criticism is greatly appreciated.
Best Regards.
Pietro
