[GRASS-dev] pygrass - stdout2dict
pygrass manual uses stdout2dict() [1] which doesn't seems to be
available. Martin
[1] http://grass.osgeo.org/grass70/manuals/libpython/pygrass_modules.html
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Tue, Apr 7, 2015 at 11:10 AM, Martin Landa <landa.martin@gmail.com> wrote:
available. Martin
While I don't know the solution, there were to related comments:
http://lists.osgeo.org/pipermail/grass-user/2014-October/071144.html
http://lists.osgeo.org/pipermail/grass-user/2014-October/071150.html
Hi Martin,
available.
You are right the function has not been defined... probably I can
simply update the docstring adding the function, something like:
def stdout2dict(stdout):
    return dict([kv.split('=') for kv in stdout.strip().split('\n')])
or with lambda
stdout2dict = lambda x: dict([i.split('=') for i in x.strip().split('\n')])
Best regards
Pietro
2015-04-07 12:58 GMT+02:00 Pietro <peter.zamb@gmail.com>:
or with lambda
hm, is there any way how to parse command output using pygrass without
need to define your own function?
Thanks, Martin
Martin Landa
Why not use: parse_key_val(s, sep='=', dflt=None, val_type=None, vsep=None)
define in grass.script.utils?
2015-04-07 13:28 GMT+02:00 Pietro <peter.zamb@gmail.com>:
you are right, are you planning to update pygrass manual? Martin
Martin Landa
done in r65015
Pietro
2015-04-07 14:09 GMT+02:00 Pietro <peter.zamb@gmail.com>:
done in r65015
Thanks, Martin
Martin Landa
