this is found on a cluster, it is running on Pythn 2.6.6, it is a 64 bit system
the svn tree is few days old, updating it now.
creating an issue here (it seems):
from grass.pygrass.modules.shortcuts import raster as r
File "./python-pygrass.py", line 54, in <module>
File "/home/ychemin/grass_dev/grass-install/grass-7.0.svn/etc/python/grass/pygrass/__init__.py",
line 17, in <module>
import modules
File "/home/ychemin/grass_dev/grass-install/grass-7.0.svn/etc/python/grass/pygrass/modules/__init__.py",
line 8, in <module>
import interface
File "/home/ychemin/grass_dev/grass-install/grass-7.0.svn/etc/python/grass/pygrass/modules/interface/__init__.py",
line 9, in <module>
import module
File "/home/ychemin/grass_dev/grass-install/grass-7.0.svn/etc/python/grass/pygrass/modules/interface/module.py",
line 11, in <module>
from xml.etree.ElementTree import fromstring
File "/usr/lib64/python2.6/xml/etree/ElementTree.py", line 758, in <module>
_escape = re.compile(eval(r'u"[&<>\"\u0080-\uffff]+"'))
File "/usr/lib64/python2.6/re.py", line 190, in compile
return _compile(pattern, flags)
File "/usr/lib64/python2.6/re.py", line 243, in _compile
p = sre_compile.compile(pattern, flags)
File "/usr/lib64/python2.6/sre_compile.py", line 510, in compile
code = _code(p, flags)
File "/usr/lib64/python2.6/sre_compile.py", line 495, in _code
_compile(code, p.data, flags)
File "/usr/lib64/python2.6/sre_compile.py", line 88, in _compile
_compile(code, av[2], flags)
File "/usr/lib64/python2.6/sre_compile.py", line 63, in _compile
_compile_charset(av, flags, code, fixup)
File "/usr/lib64/python2.6/sre_compile.py", line 189, in _compile_charset
for op, av in _optimize_charset(charset, fixup):
File "/usr/lib64/python2.6/sre_compile.py", line 232, in _optimize_charset
return _optimize_unicode(charset, fixup)
File "/usr/lib64/python2.6/sre_compile.py", line 352, in _optimize_unicode
mapping = array.array('b', mapping).tostring()
TypeError: __new__() takes at most 2 arguments (3 given)
