(script below)
I get this error
v.import_(input=adminfile,output=“admin”,quiet=True,superquiet=True)
File “/usr/lib/grass74/etc/python/grass/pygrass/modules/shortcuts.py”, line 47, in getattr
return self.cls(‘%s.%s’ % (self.prefix, name.replace(‘_’, ‘.’)))
File “/usr/lib/grass74/etc/python/grass/pygrass/modules/interface/module.py”, line 530, in init
raise GrassError(str_err % self.name)
grass.exceptions.GrassError: Error running: v.import. --interface-description
#SCRIPT
from grass_session import Session
from grass.pygrass.modules.shortcuts import vector as v
adminfile=gadm_FR_2_Morbihan.gpkg
with Session(gisdb=“/tmp”, location=“loc”, create_opts=“EPSG:4326”):
* Yann Chemin <dr.yann.chemin@gmail.com> [2018-07-25 09:34:32 +0200]:
(script below)
I get this error
v.import_(input=adminfile,output="admin",quiet=True,superquiet=True)
File "/usr/lib/grass74/etc/python/grass/pygrass/modules/shortcuts.py",
line 47, in __getattr__
return self.cls('%s.%s' % (self.prefix, name.replace('_', '.')))
File
"/usr/lib/grass74/etc/python/grass/pygrass/modules/interface/module.py",
line 530, in __init__
grass.exceptions.GrassError: Error running: `v.import.
--interface-description`.
#SCRIPT
with Session(gisdb="/tmp", location="loc", create_opts="EPSG:4326"):
Yann,
does the "typical"
grass.run_command('v.import', input=adminfile, output="admin", quiet=True, superquiet=True)
work?
Nikos
On Wed, Jul 25, 2018, 3:34 AM Yann Chemin <dr.yann.chemin@gmail.com> wrote:
(script below)
I get this error
It seems that PyGRASS does not support the “underscore at the end when Python keyword”. It just does it’s usual thing which is replacing underscores with dots like in r.slope_aspect. So probably a new functionality needs to be added to replace import_ with just import. Something like name.strip(‘_’). Please add a test for it.
Best,
Vaclav
#SCRIPT
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Wed, Aug 1, 2018 at 11:03 AM, Pietro <peter.zamb@gmail.com> wrote:
Hi Yann,
On Wed, Jul 25, 2018 at 9:34 AM, Yann Chemin <dr.yann.chemin@gmail.com>
Why are you interested to execute "v.import_(" instead of "v.import(",
what is it the purpose of this extra underscore in this case?
It is quite easy to fix this issue but actually I'm not conviced should be
fixed.
I think Yann is using shortcuts, not execution by providing module name as
a string, so than "import" is really a keyword:
a = 1
a.real
1
a.xxx
File "<stdin>", line 1, in <module>
AttributeError: 'int' object has no attribute 'xxx'
a.import()
a.import()
SyntaxError: invalid syntax
Yes I used shortcuts, the Python keyword replacement is forcing pyGRASS to make v.import_ instead of v.import. However the same “" scheme is also a replacement of triple dot separated grass modules 9i.e. r.out.gdal=> r.out_gdal) and the replacement scheme in running modules assumes that "” has to be replaced by a “.” … Thus the error ideed
yes this is the problem indeed
(script below)
I get this error
Best,
Vaclav
#SCRIPT
yes in the meantime I am running it with parse_command I believe
#code######################################################
from grass.script import core as gcore
#from grass.pygrass.modules.shortcuts import vector as v
#v.import_(input=adminfile,output=“admin”,quiet=True,superquiet=True)
gcore.parse_command(“v.import”,input=adminfile,output=“admin”,quiet=True)
On Wed, 25 Jul 2018 at 11:05, Nikos Alexandris <nik@nikosalexandris.net> wrote:
(script below)
I get this error
line 47, in getattr
File
line 530, in init
#SCRIPT
Yann,
does the “typical”
grass.run_command(‘v.import’, input=adminfile, output=“admin”, quiet=True, superquiet=True)
work?
Nikos
Thank you Yann and Vaclav, I was not aware of this issue:
On Thu, Aug 2, 2018 at 5:06 AM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
I’ve fixed the the code to support the use of underscore for python reserved words and add two doctests in r73029.
Best regards
pietro
a.import()
File “”, line 1
a.import()
Great, thanks a lot Pietro !
Best regards
pietro
a.import()
File “”, line 1
a.import()
>>> a.import()
a.import()
I've fixed the the code to support the use of underscore for python reserved
Great, thanks! Any objections to backport this?
