[GRASS-dev] pygrass
Hi PyGRASSers,
I am not exactly familiar with "grass.exceptions" modules. Am I correct in doing the following:
# transfer timestamps, if any
if timestamps:
     try:
         datetime = grass.read_command("r.timestamp", map=image)
         run("r.timestamp", map=tmp_cdn, date=datetime)
         msg = "\n|i Timestamping: %s" % datetime
         g.message(msg)
     except CalledModuleError:
         grass.fatal(_('\n|* Timestamp missing from input map! '
         'If you insist to continue without timestamps, '
         'you may use the -t flag.'))
or is there a better, more appropriate way? I've seen some examples in existing scripts.
Thanks, Nikos
