[GRASS-dev] pysal file I/O
I am trying to write a script using pysal for point pattern analysis. From their manual, “PySAL contains a new file input-output API that should be used for all file IO operations” (pysal.readthedocs.io/en/latest/users/tutorials/fileio.html).
Does anybody know or has suggestions how to get a grass vector layer ready for further analysis with pysal within a grass script using this I/O api?
Paulo
their manual, "PySAL contains a new file input-output API that should be
used for all file IO operations" (
Paulo
grass-dev mailing list
grass-dev@.osgeo
In mentioned doc, there are e.g. Shapefile or csv listed as exchange format?
AFAIU the I/O api is able to read these listed exchange formats.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/pysal-file-I-O-tp5301192p5301198.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
Paulo
grass-dev@.osgeo
Yes, but I was wondering if it would be possible without first converting / exporting to another format.
best regards
Helmut
grass-dev@lists.osgeo.org
Depends what you are planing to do in more detail. But maybe the pygrass Vector or VectorTopo module could be of help...
https://grass.osgeo.org/grass70/manuals/libpython/pygrass_vector.html
Stefan
________________________________________
Von: grass-dev [grass-dev-bounces@lists.osgeo.org] im Auftrag von Paulo van Breugel [p.vanbreugel@gmail.com]
Gesendet: Freitag, 23. Dezember 2016 22:34
An: Helmut Kudrnovsky; grass-dev@lists.osgeo.org
Betreff: Re: [GRASS-dev] pysal file I/O
Paulo
grass-dev@.osgeo
best regards
Helmut
Sent from the Grass - Dev mailing list archive at Nabble.com<http://Nabble.com>.
I am looking to use the Moran I and related statistics available in pysal in a grass script to look at point patterns, and possibly write a small addon for it (there used to be an grass addon to compute moran I, would be nice to have it again). Pysal expects as import a shapefile, csv or a few other formats. So I can export a grass vector layer to e.g., shapefile, and read that in Pysal and run my analysis. However, I thought perhaps there is a more direct way to write a grass vector layer to pysal format that people know of. If not, I'll use the grass-shapefile-pysal route.
Stefan
Paulo
grass-dev@.osgeo
best regards
Helmut
However, I
thought perhaps there is a more direct way to write a grass vector >layer
no idea if pysal is able to read from pipe, if it's about point maybe it's
possible to feed the pipe by some v.report/v.db.select/pygrass output?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/pysal-file-I-O-tp5301192p5301268.html
On Sat, Dec 24, 2016 at 3:17 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
>However, I
I'll look into it, thanks
best regards
Helmut
