[GRASS-dev] python and GRASS_MESSAGE_FORMAT
Hallo,
I would need to catch progress of r.los in one python script. I used
following approach
os.putenv("GRASS_MESSAGE_FORMAT","gui")
for line in os.popen("r.los in=elevation.dem out=tmp 2>&1").readlines():
    print line
It works well, but all the "lines" are printed out, just after r.los is
finished, but not while it is processing the raster map.
Could somebody help me, how to do it? Could you point me to tcl code,
which must solve this problem too?
Thank you
Jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
OFFICE:
Department of Geoinformation Technologies
Zemedelska 3
613 00, Brno
Czech Republick
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
following approach
    print line
The documentation for the readlines() method says:
readlines([sizehint])
    Read until EOF using readline() and return a list containing the
    lines thus read. If the optional sizehint argument is present,
    instead of reading up to EOF, whole lines totalling approximately
    sizehint bytes (possibly after rounding up to an internal buffer
    size) are read. Objects implementing a file-like interface may
    choose to ignore sizehint if it cannot be implemented, or cannot
    be implemented efficiently.
The "until EOF" means that it isn't going to return until the command
has completed.
Looking at the Python docs, you probably want something like:
  f = os.popen("r.los in=elevation.dem out=tmp 2>&1")
  try:
      for line in f:
          print line
  finally:
      f.close()
has completed.
  try:
      for line in f:
          print line
  finally:
      f.close()
thanks, Glynn, but it does not seem to work - or it works the same way,
like readlines() does.
I have in the script:
import os
f = os.popen("r.los --o in=elevation.dem out=tmp \
        coordinate=603067.6875,4925297.0625 max_dist=10000 2>&1")
try:
    for line in f:
        print line
finally:
    f.close()
result is, lines are printed. but _after_ r.los finished it's
calcualtions..
do I understand something wrong?
thanks
jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
Hi Jachym. This looks like a buffered vs. unbuffered stream problem.
Looking at lib/gis/percent.c, the output of (the G_percent calls of)
r.los should flush at every write so if you try to popen in unbuffered
mode, you should get what you need: try os.popen("your_cmd","r",0).
HTH, Daniel.
> has completed.
> try:
> for line in f:
> print line
> finally:
> f.close()
import os
try:
    for line in f:
        print line
finally:
    f.close()
calcualtions..
thanks
jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (GNU/Linux)
iD8DBQFFaJyXyKt0uAjU4I8RAmlTAKDUnIxJiatd2h/kU/OGv/LI/I1NSQCgn9BJ
1yFsraD4e8VY3nEZeozW3JM=
=K8gc
-----END PGP SIGNATURE-----
grass-dev mailing list
grass-dev@grass.itc.it
-- Daniel Calvelo Aros
HTH, Daniel.
thanks for this hint, but it does not seem, that it would help.
behaviour remain same:
import os
        coordinate=603067.6875,4925297.0625 max_dist=10000 2>&1","r",0)
try:
    for line in f:
        print line
finally:
    f.close()
jachym
>> has completed.
>> try:
>> for line in f:
>> print line
>> finally:
>> f.close()
>import os
>try:
> for line in f:
> print line
>finally:
> f.close()
>calcualtions..
>thanks
>jachym
>Jachym Cepicky
>OFFICE:
>Zemedelska 3
>613 00, Brno
>Czech Republick
>=K8gc
>_______________________________________________
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
following approach
just a note: (from distant memory)
r.los is a very inefficient module*, and its G_percent() status is
probably not linear and possibly somewhat wrong. Keep the search radius
small or you'll tie up your server's CPU for a long long time!
[*] for a replacement see r.cva from GEM/add-ons
Hamish
import os
Try with popoen3, to get all your pipes separate:
o,i,f = os.popen3("r.los --o in=elevation.dem out=tmp \
        coordinate=603067.6875,4925297.0625 max_dist=10000", bufsize=0 )
Note the omitted redirection of stderr to stdout.
try:
    for line in f:
        print line
finally:
    f.close()
jachym
same result :-/
this should be solved, before we continue on newgeneration gui too :-/
thanks
jachym
>try:
> for line in f:
> print line
>finally:
> f.close()
>jachym
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
