[GRASS-dev] Python assertion error in GRASS GIS script
Dears,
I try to understand why the following assertion fails to work, as
expected, in a Python GRASS GIS script?
The following fragment of code
fraction_categories = grass.parse_command('r.category',
                map=fractions,
                delimiter='\t')
fractions_sum = sum([float(x)
    if not math.isnan(float(x))
    else 0
    for x
    in fraction_categories.values()])
msg = "Fractions: {f}".format(f=fraction_categories)
g.message(_(msg))
g.message(_("Sum: {s}".format(s=fractions_sum)))
gives
Fractions: {u'24': u'nan', u'25': u'0.0159235666814', u'26':
u'0.0891719747445', u'27': u'nan', u'20': u'0.0238853509712', u'21':
u'0.0286624211654', u'23': u'0.143312100132', u'29': u'nan', u'40': u'nan',
u'41': u'0.0318471333627', u'1': u'nan', u'3': u'nan', u'2':
u'0.0159235669187', u'5': u'nan', u'4': u'nan', u'7': u'nan', u'6': u'nan',
u'9': u'nan', u'8': u'nan', u'11': u'0.00159235669186', u'10': u'nan',
u'12': u'0.162420386604', u'15': u'0.366242033672', u'16': u'nan', u'18':
u'0.0573248423308', u'31': u'nan', u'36': u'nan', u'35':
u'0.0636942667255', u'32': u'nan'}
Sum: 1.0
Yet the following assertion does not work as expected
assert fractions_sum < 1.000000000000001, "Sum of fractions is > 1"
and returns
  File "/osgeo/grasstrunk/dist.x86_64-pc-linux-gnu/scripts/r.estimap", line 3979, in <module>
    sys.exit(main())
  File "/osgeo/grasstrunk/dist.x86_64-pc-linux-gnu/scripts/r.estimap", line 3964, in main
    **supply_parameters)
  File "/osgeo/grasstrunk/dist.x86_64-pc-linux-gnu/scripts/r.estimap", line 2864, in compute_supply
AssertionError: Sum of fractions is > 1
The following _does_ work, in Python (inside a GRASS GIS session),
import os, sys, subprocess
import datetime, time
import csv
import math
import atexit
import grass.script as grass
from grass.exceptions import CalledModuleError
from grass.pygrass.modules.shortcuts import general as g
from grass.pygrass.modules.shortcuts import raster as r
from grass.pygrass.modules.shortcuts import vector as v
fractions_sum = 1.
Nikos
On Mon, Oct 8, 2018 at 6:43 PM Nikos Alexandris <nik@nikosalexandris.net> wrote:
Dears,
map=fractions,
delimiter='\t')
else 0
for x
g.message(_(msg))
gives
Sum: 1.0
and returns
sys.exit(main())
What is the sum when printed out with %.17g?
Why do you use 1.000000000000001 and not e.g. 1.000001 as threshold? 1.000000000000001 is most probably a too small difference to 1 considering floating point precision limits.
Markus M
The following does work, in Python (inside a GRASS GIS session),
import csv
import math
import atexit
fractions_sum = 1.
Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
                map=fractions,
                delimiter='\t')
    else 0
    for x
g.message(_(msg))
gives
u’nan’,
u’41’: u’0.0318471333627’, u’1’: u’nan’, u’3’: u’nan’, u’2’:
u’0.0159235669187’, u’5’: u’nan’, u’4’: u’nan’, u’7’: u’nan’, u’6’:
u’nan’,
u’9’: u’nan’, u’8’: u’nan’, u’11’: u’0.00159235669186’, u’10’: u’nan’,
u’12’: u’0.162420386604’, u’15’: u’0.366242033672’, u’16’: u’nan’, u’18’:
u’0.0573248423308’, u’31’: u’nan’, u’36’: u’nan’, u’35’:
u’0.0636942667255’, u’32’: u’nan’}
Sum: 1.0
assert fractions_sum < 1.000000000000001, “Sum of fractions is > 1”
and returns
File “/osgeo/grasstrunk/dist.x86_64-pc-linux-gnu/scripts/r.estimap”,
line 3979, in
sys.exit(main())
line 3964, in main
Markus Metz:
Bingo!
Following is from a script run, not from the fractions posted in this
thread.
Sum: 1.0000000000003
  File "/osgeo/grasstrunk/dist.x86_64-pc-linux-gnu/scripts/r.estimap", line 4207, in <module>
    sys.exit(main())
  File "/osgeo/grasstrunk/dist.x86_64-pc-linux-gnu/scripts/r.estimap", line 4192, in main
  File "/osgeo/grasstrunk/dist.x86_64-pc-linux-gnu/scripts/r.estimap", line 3019, in compute_supply
Because of this (wrong I understand now) quick trial and error:
In [5]: 1.00000000000001 > 1
Out[5]: True
In [6]: 1.000000000000001 > 1
Out[6]: True
In [7]: 1.0000000000000001 > 1
Out[7]: False
It is. But then again, how do I decide how "loose" it can be?
1.01?
1.001?
1.0001?
N
On Fri, Oct 12, 2018 at 11:22 PM Nikos Alexandris <nik@nikosalexandris.net> wrote:
It is. But then again, how do I decide how “loose” it can be?
1.01?
1.001?
1.0001?
From experience I recommend 1 + 1e-6 which is a bit lower than the minimum single precision floating point limit.
Instead of
try
assert abs(fractions_sum - 1) < 1e-6, “Sum of fractions is != 1”
You should not go lower than 1e-15 because here you are hitting the double precision floating point limit.
Markus M
considering
Nikos:
1.01?
1.001?
1.0001?
Markus:
Instead of
try
assert abs(fractions_sum - 1) < 1e-6, "Sum of fractions is != 1"
That's really smart. The fractions are fragments from the same "sum",
so this assertion refers exactly to this: their "sum" being close to 1.
This is what I need!
Kudos, Nikos
