Hi Soeren,
I’ve tried v.mapcalc from Thomas’ GSoC and I think it should go at least to Addons. Does one of you want to commit it or should I do that? Some, rather trivial, changes are need to make it work (attached), I can apply them later if you want.
I also suggest removing the v.mapcalc which is now in addons. Perhaps the functionality is different but since it was not finished, there is no functionality which can be used. Unless somebody will work on it soon, I don’t see a reason to keep it there. (Alternatively, it can be renamed.)
Best,
Vaclav
(attachments)
vmapcalc.patch (8.43 KB)
On Tue, Oct 13, 2015 at 3:15 AM, Sören Gebbert <soerengebbert@googlemail.com> wrote:
the GSoC implementation of v.mapcalc is still available:
https://code.google.com/p/grass-gis-temporal-algebra/source/browse/#svn%2Ftrunk%2Fv.mapcalc
However, the approach in the GSoC v.mapcalc is very different from the
v.mapcalc addon from 2002.
The algebraic expressions are applied to whole vector maps, rather
than single points, list of points, lines or polygons.
Best regards
Soeren
2015-10-13 3:53 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
On Mon, Oct 12, 2015 at 6:24 AM, Glynn Clements <glynn@gclements.plus.com>
wrote:
Markus Neteler wrote:
<p.vanbreugel@gmail.com> wrote:
Sorry for the late follow up. The add-on installs now. When trying to
run
it, however, nothing happens.
It does not have a parser (yet?), so I suppose it reads from stdin.
Yes.
But it doesn’t have any code to read or write GRASS vectors, either.
v.mapcalc appears to be a work-in-progress which hasn’t actually made
noticeable progress since it was added.
Then I suggest to remove it from the Makefile parent directory and also
disable it in the addons build scripts if there is something more needed
than r66406 [1] which is blacklisting it somehow already. It does not
fulfill what user would expect (at least some functionality). Those who want
to continue development will get it through svn.
I’m not sure happened [2] with the v.mapcalc implemented as a test case in
GSoC [3] and if the functionality can be still used. But this seems like a
good alternative to the code in addons.
Vaclav
[1] https://trac.osgeo.org/grass/changeset/66406
[2] https://lists.osgeo.org/pipermail/grass-dev/2013-October/065908.html
[3]
https://grasswiki.osgeo.org/wiki/GRASS_GSoC_2013_Temporal_GIS_Algebra_for_raster_and_vector_data_in_GRASS#v.mapcalc
grass-dev mailing list
grass-dev@lists.osgeo.org
+1
2016-01-05 8:47 GMT+01:00 Thomas Leppelt <thomas.leppelt@gmail.com>:
Hi Vaclav,
it would be nice, if you commit v.mapcalc to Addons.
Thanks
Thomas
On Tue, Jan 5, 2016 at 4:52 AM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Hi Soeren,
I've tried v.mapcalc from Thomas' GSoC and I think it should go at least
don't see a reason to keep it there. (Alternatively, it can be renamed.)
Best,
Vaclav
Best regards
Soeren
>> > > to
>> > > run
>> Yes.
>> But it doesn't have any code to read or write GRASS vectors, either.
>> v.mapcalc appears to be a work-in-progress which hasn't actually made
> needed
> want
> I'm not sure happened [2] with the v.mapcalc implemented as a test case
> in
> like a
> Vaclav
> [2]
> [3]
On 05/01/16 04:52, Vaclav Petras wrote:
Hi Soeren,
to Addons.
+1
Moritz
On Tue, Jan 5, 2016 at 2:47 AM, Thomas Leppelt <thomas.leppelt@gmail.com>
Done.
Rename v.mapcalc to v.feature.algebra and disable it:
https://trac.osgeo.org/grass/changeset/67492
https://trac.osgeo.org/grass/changeset/67493
Add and update Python v.mapcalc:
https://trac.osgeo.org/grass/changeset/67494
https://trac.osgeo.org/grass/changeset/67495
https://trac.osgeo.org/grass/changeset/67496
Hi Martin,
I see that the Addons index page was compiled but don’t see any changes (there, in individual pages or in logs). Can you please look at that? I was changing the directory Makefile and renaming directories, so I’m not sure if this could cause something.
Vaclav
On Tue, Jan 5, 2016 at 10:49 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
On Tue, Jan 5, 2016 at 2:47 AM, Thomas Leppelt <thomas.leppelt@gmail.com> wrote:
Done.
2016-01-06 5:50 GMT+01:00 Vaclav Petras <wenzeslaus@gmail.com>:
I see that the Addons index page was compiled but don't see any changes
changing the directory Makefile and renaming directories, so I'm not sure if
right, `svn up` failed with
svn: Failed to add directory 'grass7/vector/v.mapcalc': an unversioned
directory of the same name already exists
Fixed. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Done.
Great. This is a wonderful tool, thanks !
One observation: at the end g.rename is run with overwrite=TRUE, which means that v.mapcalc mimics the behaviour of the old r.mapcalc which just overwrote existing maps. Would it be possible to change this so that v.mapcalc has and --overwrite flag and does not just overwrite existing maps if this is not set ?
Moritz
