On Aug 12, 2008, at 3:22 PM, Glynn Clements wrote:
Michael Barton wrote:
With the revamp of the GRASS graphic driver output system, I'm
wondering about the feasibility of having a driver that creates a
Python data object rather than a disk file.
Can you elaborate?
Specifically, how is the data supposed to be transferred from the d.*
command to the GUI?
A couple new modules seem promising in this regard:
BitmapFromBuffer:
"Two new wx.Bitmap factory functions allow you to create a wx.Bitmap directly from a data buffer. The the buffer can be any Python object that implements the buffer interface, or is convertable to a buffer, such as a string or an array. The new functions are:
wx.BitmapFromBuffer(width, height, dataBuffer, alphaBuffer=None): Creates the bitmap from a buffer of RGB bytes, optionally with a separate buffer of alpha bytes.
wx.BitmapFromBufferRGBA(width, height, dataBuffer): Creates the bitmap from a buffer containing RGBA bytes. "
ImageFromStream:
"At long last there is finally a way to load any supported image type
directly from any Python file-like object, such as a memory buffer
using StringIO."
Both seem to allow python data objects, rather than files to be the source of bitmaps for display
While this might not
create noticeable speed improvements in rendering displays in a Python
canvas, it could considerably simplify coding for overlaying and
rendering multiple geospatial data layers--especially if we can do the
compositing and rendering with Python tools rather than g.pnmcomp.
Even with the modules writing image files, the compositing step really
should be performed within Python, rather than using an external
process (g.pnmcomp). This would mean that enabling or disabling layers
or changing the translucency level would happen instantly.
AFAICT, wx itself doesn't have code for this, although there may be
third-party libraries which do. GDK has compositing code which can use
SSE; it may be worth taking that (if someone hasn't already).
It seems like the new GraphicContext does this:
"The new advanced 2D drawing API is implemented via the wx.GraphicsContext and wx.GraphicsPath classes. They wrap GDI+ on Windows, Cairo on wxGTK and CoreGraphics on OS X. They allow path-based drawing with alpha-blending and anti-aliasing, and use a floating point cooridnate system.
When viewing this sample pay attention to how the rounded edges are smoothed with anti-aliased drawing, and how the shapes on the lower half of the window are partially transparent, allowing you to see what was drawn before."
Better still, if you use cairo, it should be possible to have the
graphics hardware perform the compositing.
The cairo driver has support for using an X Pixmap for its output (via
GRASS_CAIRO_DRAWABLE and GRASS_CAIRO_VISUAL). Not only would this
eliminate the need to copy data to/from disk (or even between
processses), but the d.* command can use the graphics hardware.
This also sounds promising if it could be implemented from the Python GUI.
Michael
