Hi All,
i'm tring to utilize a python function iside the grass environment,
but i gett errors about :
"Incompatible library version for module"
outside a running GRASS, it works from python. From python started inside a GRASS shell, it doesn't work.
the function i'm using is prety simple :
import os
import subprocess
def OssimImg2rr(img1):
os.environ['DYLD_FRAMEWORK_PATH'] = '/var/tmp/XcodeBuilds/Release'
os.environ['OSSIM_PREFS_FILE'] = '/Users/sasha/ossim_preferences'
output = subprocess.Popen(['/var/tmp/XcodeBuilds/Release/img2rr' ,str(img1)],stdout=subprocess.PIPE).communicate()[0]
as i described first,
these code works fine in a standard python shall, but if i try to run it from python iside grass shell, i get the error about incompatible library version.
note :
the same code works fine on linux, without erors.
i tried to buuild both grass and ossim using the same gdal.framework as dependencies,
i tried to run (in osx) the same code in grass65 (thinking about a gdal-grass version problem) but nothing, the error pesists
i don't think is a gdal issue beacouse img2rr do not use gdal, but it is a simple unix command wrapper.
maybe it is a problem related to
import os
import subprocess
Sounds like GRASS is corrupting the python environment somehow.
have youy any clue ?
thanks for any help!
regards,
Massimo Di Stefano
massimodisasha@yahoo.it
epifanio on irc.freenode.net /join gfoss
Chiacchiera con i tuoi amici in tempo reale! http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
