I have GRASS 7.3.svn (r71212). In python , calling grass.script I get:
import grass.script as grass
File “”, line 1, in
File “/usr/local/grass-7.3.svn/etc/python/grass/script/init.py”, line 5, in
from .core import *
File “/usr/local/grass-7.3.svn/etc/python/grass/script/core.py”, line 35, in
gettext.install(‘grasslibs’, os.path.join(os.getenv(“GISBASE”), ‘locale’))
File “/usr/lib64/python2.7/posixpath.py”, line 70, in join
elif path == ‘’ or path.endswith(‘/’):
AttributeError: ‘NoneType’ object has no attribute ‘endswith’
Works just fine here.
What is the output of os.getenv("GISBASE")? Are you trying to run this
code outside of GRASS GIS session (this could explain lack of GISBASE
environmental setting)?
Māris.
2017-06-29 18:00 GMT+03:00 Margherita Di Leo <diregola@gmail.com>:
File "<stdin>", line 1, in <module>
File "/usr/local/grass-7.3.svn/etc/python/grass/script/__init__.py", line
5, in <module>
from .core import *
File "/usr/local/grass-7.3.svn/etc/python/grass/script/core.py", line 35,
in <module>
gettext.install('grasslibs', os.path.join(os.getenv("GISBASE"),
'locale'))
File "/usr/lib64/python2.7/posixpath.py", line 70, in join
elif path == '' or path.endswith('/'):
AttributeError: 'NoneType' object has no attribute 'endswith'
Maris, thank you for checking this!! Was my mistake, I hadn’t noticed that I had a duplication of import grass.script as grass, the one throwing the error was at the top of the script before declaring GISBASE… need holidays I guess… sorry for the noise.
What is the output of os.getenv(“GISBASE”)? Are you trying to run this
File “”, line 1, in
5, in
from .core import *
in
‘locale’))
