[GRASS-dev] Python GUI requirements
REQUIREMENTS.html mentions Python for the GUI, but a couple things are missing:
Is there a minimum version requirement?
It doesn't have wxPython as a requirement.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
2008/1/13, William Kyngesburye <woklist@kyngchaos.com>:
missing:
updated now in trunk
http://trac.osgeo.org/grass/changeset/29697
Martin
robot?
answer...
grass-dev mailing list
grass-dev@lists.osgeo.org
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
current trunk ./configure --help says that --with-python will enable
Python support (Python bindings?). Still I don't see any switch to
enable/disable wxpython. Shouldn't there be one?
Maris.
2008/1/13, Maris Nartiss <maris.gis@gmail.com>:
yes, --wxpython is still missing. In my long-term TODO;-)
Martin
From what I could figure out about configure and make for GRASS Python:
--with-python enables wxpython. See gui/Makefile.
The swig bindings are manually built -- see the note in swig/makefile. And they don't appear to have any connection with --with-python.
On Jan 13, 2008, at 1:09 PM, Maris Nartiss wrote:
Maris.
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
Which REQUIREMENTS.html document are you referring to?
For the wxPython GUI, you need Python 2.4 or greater and wxPython 2.8 or higher (maybe 2.8.1, but you might need to ask Martin on that).
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
python.
I added --with-wxpython option to configure script. wxPython requires
--with-python, also checks for python version >= 2.4 and wxpython >=
2.8.
Martin
> Hi,
> Maris.
Yes.
Still I don't see any switch to enable/disable wxpython. Shouldn't
there be one?
It isn't needed. The Tcl/Tk and Python checks in gui/Makefile are both
bogus; those directories should be processed regardless of whether or
not Tcl/Tk or Python are installed on the build system.
The Tcl/Tk check is meant for code which links against the Tcl/Tk
libraries, namely NVIZ, v.digit and the form library.
2008/1/14, Glynn Clements <glynn@gclements.plus.com>:
Yes.
> there be one?
now gui/Makefile checks for wxPython instead of Python. wxPython stuff
is installed only if --with-wxpython is given.
Martin
On Mon, 14 Jan 2008, Martin Landa wrote:
Yes.
there be one?
I think Glynn's point was that the installation should simply be unconditional with no checks in gui/Makefile - the wxPython stuff is just scripts and doesn't need Python to be installed on the compilation system for the scripts to be processed in any way (unlike C compiling) - the requirement for wxPython is only on the system that GRASS is run on so it should be a runtime check rather than a comile-time check.
Of course if the wxPython stuff does require Python on the compilation system, then what I've said is totally wrong...
Paul
>> Yes.
>>> there be one?
Exactly.
If you're cross-compiling e.g. building a Windows version on a Linux
system, you shouldn't need to have a Windows version of
Python/wxPython installed on the build system.
Configure checks identify the compilation environment, not the
run-time environment.
