[GRASS-dev] python issues
Thomas wrote:
I am aware that after installing GRASS I have to run
Init.sh in /etc of the sources, but it stops with:
./Init.sh: line 412: /etc/clean_temp: No such file or
directory
Starting GRASS ...
Error in startup script: couldn't read file
"/etc/gis_set.tcl": no such file or directory
start grass with the "grass64" script, not with Init.sh.
all the grass64 script does is set the $GISBASE variable then call
Init.sh, but that is the critical grass variable.
  with $GISBASE expands to
"/usr/local/grass64/etc/gis_set.tcl"
etc.
see also the batch scripting wiki page which tells you how to run grass
without init.sh
Hamish
