[GRASS-dev] Python location wizard broken
On Jan 30, 2008, at 8:54 PM, grass-dev-request@lists.osgeo.org wrote:
Date: Wed, 30 Jan 2008 22:00:48 +0100
Subject: [GRASS-dev] Python location wizard broken
To: "GRASS developers list" <grass-dev@lists.osgeo.org>
Message-ID:
  <86782b610801301300j5fdcb236l3f8327a5ddaf7ad@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
currently the Python location wizard is broken...
grass63 -wx
Cleaning up temporary files.....
Starting GRASS ...
  File "/home/neteler/grass63/dist.i686-pc-linux-gnu/etc/wx/gis_set.py",
line 374, in OnWizard
    gWizard = location_wizard.LocationWizard(self, self.tgisdbase.GetValue())
  File "/home/neteler/grass63/dist.i686-pc-linux-gnu/etc/wx/gui_modules/location_wizard.py",
line 1592, in __init__
    self.projtypepage.DoLayout()
line 118, in DoLayout
    tmpsizer.Fit(self)
  File "/usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_core.py",
line 12558, in Fit
    return _core_.Sizer_Fit(*args, **kwargs)
wx._core.PyAssertionError: C++ assertion "uiIndex < m_nCount" failed
at ../include/wx/dynarray.h(813) in Item()
Markus,
It's working with OS X on the version I compiled from the trunk last night. Did you upgrade your wxPython or make some other system change?
Michael
Michael,
no system change at all (it is an older Mandriva 2007.0 box).
I have installed:
rpm -qa | grep wx
wxPython-common-gtk2-unicode-2.8.3.0-1_py2.4
libwxgtku2.6-2.6.3-7mdv2007.0
libwxgtkglu2.7-2.7.0-2mdv2007.0
libwxPythonGTK2.6-2.6.3.3-2.1mdv2007.0
libwxgtku2.7-devel-2.7.0-2mdv2007.0
wxPython2.8-devel-gtk2-unicode-2.8.3.0-1_py2.4
wxgtk2.7-2.7.0-2mdv2007.0
wxGTK2.6-2.6.3-7mdv2007.0
libwxgtku2.7-2.7.0-2mdv2007.0
wxPython2.8-gtk2-unicode-2.8.3.0-1_py2.4
wxgrass starts, only the Location Wizard is broken here.
uname -a
Linux localhost 2.6.17-11mdv #1 SMP Tue Feb 13 11:59:10 MST 2007 i686
Intel(R) Pentium(R) 4 CPU 2.53GHz GNU/Linux
> From: "Markus Neteler" <neteler@osgeo.org>
> Message-ID:
> Hi,
> grass63 -wx
> Starting GRASS ...
> gis_set.py",
> tmpsizer.Fit(self)
> _core.py",
> line 12558, in Fit
> Markus
Markus,
Michael
grass-dev mailing list
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
2008/1/31, Markus Neteler <neteler@osgeo.org>:
Markus:
I have installed:
rpm -qa | grep wx
uname -a
here seems to work (python 2.4.4, wxpython 2.8.7.1). Try to
comment-out line 118 in gui_modules/location_wizard.py.
Helps?
Regards, Martin
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
Markus, Martin,
We just ran into a similar message in my lab yesterday. It was on a Mac with wxPython 2.8.3 installed. When we upgraded to 2.8.6, all was fine. I'm suspicious however. The line that says it has problems is a normal sizer command. So it might be a red herring. Maybe Martin has figured it out.
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
On Feb 2, 2008, at 10:41 AM, Martin Landa wrote:
Markus:
I have installed:
rpm -qa | grep wx
uname -a
Helps?
Regards, Martin
On Feb 2, 2008 6:41 PM, Martin Landa <landa.martin@gmail.com> wrote:
Markus:
> I have installed:
> rpm -qa | grep wx
> uname -a
Helps?
I am afraid not:
vim gui_modules/location_wizard.py
make
grass63 -wx
Starting GRASS ...
WARNING: Digitization tool is disabled (No module named
grass6_wxvdigit). Detailed information in README file.
line 119, in DoLayout
    self.Layout()
line 10236, in Layout
    return _core_.Window_Layout(*args, **kwargs)
