[GRASS-dev] Python module gui inputs
This is my first foray into grass scripting. I'm working on a GRASS 7
python module to create a local relief model from a lidar derived
surface. The code works, but for some reason in the auto generated gui
for the tool, the field to enter a neighborhood size to use for the
low pass filter doesn't appear. my module code is below. Any
assistance would be greatly appreciated.
Eric
#%module
#% description: Creates a Local Relief Model from input raster.
#% keywords: lrm
#% keywords: lidar
#% overwrite: yes
#%end
#%option G_OPT_R_INPUT
#% key:input_map
#% description: Select input raster
#% required: yes
#%end
#%option
#% key: output_map
#% type: string
#% description: Name for output LRM raster
#% required: yes
#%end
#%option
#% key: neighbor_size
#% type: double
#% description: The neighborhood size to be used in the low pass
filter. Default is 25.
#% required: no
#% answer: 25
#%end
2013/2/27 Eric Goddard <egoddard1010@gmail.com>:
Hi Eric,
Eric
#%module
#% keywords: lrm
#% keywords: lidar
#% overwrite: yes
#%end
#% key:input_map
#% required: yes
#%end
#%option
#% key: output_map
#% type: string
#% required: yes
#%end
#%option
#% type: double
#% required: no
#% answer: 25
#%end
I would like to change the description of module as following, for a
more compliant GRASS description.
I think this should work. Otherwise could you paste you entire code
(better in a external site as pastebin)
#%module
#% keywords: lrm
#% keywords: lidar
#% overwrite: yes
#%end
#%end
#%option G_OPT_R_OUTPUT
#%end
#%option
#% type: double
#% required: no
#% answer: 25
#%end
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Thanks for the response, Luca. I've made the change to the output
option, but the neighbor_size option still isn't appearing in the gui.
The descriptions will become more verbose once the code and everything
is working; what is in the script now is just the bare minimum for it
to run. and generate a gui. I've pasted the full code at
http://pastebin.com/4PCJ0xeG.
Hi Eric,
Eric
#%module
#% keywords: lrm
#% keywords: lidar
#% overwrite: yes
#%end
#% key:input_map
#% required: yes
#%end
#%option
#% key: output_map
#% type: string
#% required: yes
#%end
#%option
#% type: double
#% required: no
#% answer: 25
#%end
#%module
#% keywords: lrm
#% keywords: lidar
#% overwrite: yes
#%end
#%end
#%end
#%option
#% type: double
#% required: no
#% answer: 25
#%end
ciao
Luca
www.lucadelu.org
Hi Eric, for me it works (with code from paste bin). GUI shows and
neighbor_size is in the Optional tab.
Another suggestions about options: If the "description" is long, you
can use "label" which will be shown in the gui and description will
become a tooltip. There is usually no need to write default value into
the description since default value is already in the gui or in
y.our.module --help.
I'm afraid that the programming manual does not list these practices.
http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing
Vaclav
Hi Eric,
Eric
#%module
#% keywords: lrm
#% keywords: lidar
#% overwrite: yes
#%end
#% key:input_map
#% required: yes
#%end
#%option
#% key: output_map
#% type: string
#% required: yes
#%end
#%option
#% type: double
#% required: no
#% answer: 25
#%end
#%module
#% keywords: lrm
#% keywords: lidar
#% overwrite: yes
#%end
#%end
#%end
#%option
#% type: double
#% required: no
#% answer: 25
#%end
ciao
Luca
www.lucadelu.org
grass-dev mailing list
grass-dev@lists.osgeo.org
Thanks for the suggestions. I figured out the problem – somehow an older version of my code was getting built and I wasn’t following all the steps correctly on the grass and python wiki. The GUI works now, but my code logic still needs some work.
Eric
Another suggestions about options: If the “description” is long, you
can use “label” which will be shown in the gui and description will
I’m afraid that the programming manual does not list these practices.
Vaclav
Thanks for the response, Luca. I’ve made the change to the output
option, but the neighbor_size option still isn’t appearing in the gui.
to run. and generate a gui. I’ve pasted the full code at
Hi Eric,
Eric
#%module
#% keywords: lrm
#% keywords: lidar
#% overwrite: yes
#%end
#% key:input_map
#% required: yes
#%end
#%option
#% key: output_map
#% type: string
#% required: yes
#%end
#%option
#% type: double
#% required: no
#% answer: 25
#%end
#%module
#% keywords: lrm
#% keywords: lidar
#% overwrite: yes
#%end
#%end
#%end
#%option
#% type: double
#% required: no
#% answer: 25
#%end
ciao
Luca
www.lucadelu.org
