Unfortunately builtins is used also in other files, and I’m afraid
that I should also fix these:
$ rg "builtins" . -B 1 -A 5
script/task.py
24-try:
25: from builtins import unicode
26- bytes = str
27-except ImportError:
28- # python3
29- unicode = str
30-
temporal/core.py
38-try:
39: from builtins import long
40-except ImportError:
41- # python3
42- long = int
43-
44-from .c_libraries_interface import *
script/vector.py
27- # python3
28: import builtins as __builtin__
29- unicode = str
30-
31-from .utils import parse_key_val
32-from .core import *
33-from grass.exceptions import CalledModuleError
script/temporal_script_utils_encoding.diff
10-+try:
11:+ from builtins import unicode
12-+except ImportError:
13-+ # python3
14-+ unicode = str
15-+
16-+
script/raster.py
31-try:
32: from builtins import unicode
33- bytes = str
34-except ImportError:
35- # python3
36- unicode = str
37-
gunittest/utils.py
59- except ImportError:
60: import builtins as __builtin__
61- __builtin__._ = new_translator
62-
63-
64-_MAX_LENGTH = 80
65-
pygrass/vector/table.py
13-try:
14: from builtins import long, unicode
15-except ImportError:
16- # python3
17- long = int
18- unicode = str
19-
script/core.py
43- # python3
44: import builtins as __builtin__
45- from os import environb as environ
46- unicode = str
47-__builtin__.__dict__['_'] = __builtin__.__dict__['_'].__self__.lgettext
48-
49-
ctypes/OBJ.x86_64-pc-linux-gnu/temporal.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/cluster.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/ogsf.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/proj.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/vector.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/stats.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/arraystats.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/vedit.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/rowio.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/display.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/date.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/raster3d.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/segment.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/gis.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/nviz.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/gmath.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/rtree.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/raster.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/dbmi.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/imagery.py
13-try:
16- long = int
17-
18-import os
19-import sys
ctypes_pregit/ctypesgencore/processor/operations.py
97-def fix_conflicting_names(data, opts):
98: """If any descriptions from the C code would overwrite Python builtins or
99- other important names, fix_conflicting_names() adds underscores
to resolve
100- the name conflict."""
101-
102- # This is the order of priority for names
103- descriptions = data.functions + data.variables + data.structs + \
124- important_names[name] = "a name needed by ctypes or ctypesgen"
125: for name in dir(__builtins__):
126- important_names[name] = "a Python builtin"
127- for name in opts.other_known_names:
128- important_names[name] = "a name from an included Python module"
129- for name in keyword.kwlist:
130- important_names[name] = "a Python keyword"
ctypes/ctypesgencore/printer/preamble.py
1-try:
2: from builtins import long
3-except ImportError:
4- long = int
5-
6-import os
7-import sys
ctypes/ctypesgencore/parser/lex.py
31-try:
32: from builtins import bytes
33- PY3 = True
35- # python2
36- bytes = str
37- PY3 = False
ctypes/ctypesgencore/parser/cgrammar.py
13-try:
16- # python3
17- long = int
18-
19-__docformat__ = 'restructuredtext'
ctypes/ctypesgencore/processor/operations.py
to resolve
101-
pygrass/vector/testsuite/test_table.py
7-try:
8: from builtins import long
9-except ImportError:
10- # python3
11- long = int
12-
13-import os
25-try:
26: from builtins import long
28- long = int
29-
30-# dictionary that generate random data
31-COL2VALS = {'INT': lambda n: np.random.randint(9, size=n),
ctypes/ctypesgencore/parser/pplexer.py
13-try:
15- PY2 = True
16-except ImportError:
17- # python3
18- PY2 = False
19- long = int
