I was wandering: does exist a python::core function capable to mogrigy the inputs of a run_command()?
The mogrify function for psycopg2 is defined as follows:
“Return a query string after arguments binding. The string returned is exactly the one that would be sent to the database running the execute() method or similar.”
cur.mogrify(“INSERT INTO test (num, data) VALUES (%s, %s)”, (42, ‘bar’))
“INSERT INTO test (num, data) VALUES (42, E’bar’)”
…so for GRASS it could be:
grass.mogrify_command(“r.univar”,flags=“g”,map=“test”)
“r.univar -g map=test”
This could be helpful in debugging…
Maxi
Dr. Eng. Massimiliano Cannata
Responsabile Area Geomatica
Istituto Scienze della Terra
Scuola Universitaria Professionale della Svizzera Italiana
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
