Hello all,
Luca, I am so sorry, for the very very big delay was having my finals, and today I finally completed writing test on r.basins.fill.
All, I am Sunveer Singh, 15 years old from India, Google Code-in 2017 Winner with OSGeo, I completed 16 tasks for GRASS GIS, within Google Code-in, and contributed test for r.info, i.vi, v.extract, v.univar, v.select, r.report, r.texture, v.vect.stats, r.recode, r.in.ascii and r.to.vect. And created a video on How to create a location: Link to Video.
Due to my finals, I was unable to contribute to GRASS, but know I will start Contributing again.
I have attached my test written in python for r.basins.fill. If any improvement is needed in the test, please let me know.
Thank You for Your Precious Time.
(attachments)
testrbf.py (2.64 KB)
Thank You
Sunveer
https://sunveersingh.github.io/
On 23 March 2018 at 04:12, Sunveer Singh <singhsunveer54@gmail.com> wrote:
Hello all,
Hi Sunveer,
no problem, take care of your studies...
Contributing again.
Great the test is working well with nc_spm8_08_grass7, but most of the
actual test [0] are run in nc_basic_spm_grass7 [1].
You should change some input data and also the name of some variable
like cnetwork or tnetwork because they aren't much clear.
Please if you need more help let me/us know
thanks to you
Thank You
Sunveer
[0] http://fatra.cnr.ncsu.edu/grassgistests/summary_report/nc/index.html
[1] https://grass.osgeo.org/sampledata/north_carolina/nc_basic_spm_grass7.tar.gz
ciao
Luca
www.lucadelu.org
Thanks for the feedback, I have attached the complete working test, run on nc_basic_spm_grass7
(attachments)
testrbf.py (2.59 KB)
On Fri, Mar 23, 2018 at 10:07 PM, Luca Delucchi <lucadeluge@gmail.com> wrote:
Hello all,
Hi Sunveer,
no problem, take care of your studies…
Contributing again.
like cnetwork or tnetwork because they aren’t much clear.
thanks to you
Thank You
Sunveer
ciao
Luca
www.lucadelu.org
Thank You
Sunveer
On 24 March 2018 at 03:33, Sunveer Singh <singhsunveer54@gmail.com> wrote:
Hi Sunveer,
nc_basic_spm_grass7
thanks a lot, submitted in r72546.
https://trac.osgeo.org/grass/changeset/72546
Thank You
Sunveer
ciao
Luca
www.lucadelu.org
Thanks a lot.
Now on which module should I write test?
Thank You
Sunveer
Hi Sunveer,
nc_basic_spm_grass7
Thank You
Sunveer
ciao
Luca
www.lucadelu.org
Hi Sunveer,
It’s great to have you back!! Thanks much for your contributions and enthusiasm!
Here are some modules that are lacking tests:
v.to.db
v.to.rast
v.support
r.what
several r.out.* modules
i.pca
Cheers from the code sprint in Bonn
Vero
2018-03-24 10:08 GMT+01:00 Sunveer Singh <singhsunveer54@gmail.com>:
Thanks a lot.
Thank You
Sunveer
Hi Sunveer,
nc_basic_spm_grass7
Thank You
Sunveer
ciao
Luca
www.lucadelu.org
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Let’s, start with v.to.db, I attached the test for it.
if any improvements are needed, please let me know.
(attachments)
testvtd.py (1.87 KB)
On Sat, Mar 24, 2018 at 5:19 PM, Veronica Andreo <veroandreo@gmail.com> wrote:
Hi Sunveer,
v.to.db
v.to.rast
v.support
r.what
i.pca
Vero
Thank You
Sunveer
Thanks a lot.
Thank You
Sunveer
Hi Sunveer,
nc_basic_spm_grass7
Thank You
Sunveer
ciao
Luca
www.lucadelu.org
On 24 March 2018 at 16:48, Sunveer Singh <singhsunveer54@gmail.com> wrote:
Hi Sunveer,
Let's, start with v.to.db, I attached the test for it.
I'm sorry but you should change something.
In setUpClass you should copy the geology map because I run the script
in user1 mapset and it failed.
In tearDownClass you should remove the created map.
Thank You
Sunveer
ciao
Luca
www.lucadelu.org
Done, attached the working file!
(attachments)
testvtd.py (2.03 KB)
Hi Sunveer,
I’m sorry but you should change something.
Thank You
Sunveer
ciao
Luca
www.lucadelu.org
Thank You
Sunveer
On 25 March 2018 at 06:56, Sunveer Singh <singhsunveer54@gmail.com> wrote:
Hi Sunveer,
yes it is working and it finish but I get several errors (attached to log file).
Some other suggestion:
- rename the copied vector with a different name
- in the copied vector create a new column and use this one to update the values
Thank You
thanks to you
Sunveer
ciao
Luca
www.lucadelu.org
Sorry I forget the file
ciao
Luca
www.lucadelu.org
(attachments)
error.7z (2.03 KB)
Sorry, but I don’t get you if I rename the mapold, I also have to rename the main map.
Can you please explain more
ciao
Luca
www.lucadelu.org
Thank You
Sunveer
On 25 March 2018 at 12:59, Sunveer Singh <singhsunveer54@gmail.com> wrote:
Sorry, but I don't get you if I rename the mapold, I also have to rename the
main map.
no no you have to assign new name to mapold (no geology) and probably
could make sense to use a different name per mapold (like mapused or
similar)
ciao
Luca
www.lucadelu.org
The error we were getting are now fixed.
File Attached, if any improvements are needed please let me know.
(attachments)
testvtd.py (2.11 KB)
main map.
similar)
ciao
Luca
www.lucadelu.org
Thank You
Sunveer
