Glynn,
See below...
On Jul 29, 2008, at 6:36 AM, Glynn Clements wrote:
Michael Barton wrote:
AFAICT, everything works without $PYTHONPATH in all cases EXCEPT in
a script running under the GRASS parser.
So what changes before and after g.parser?
In the scripts which I have seen so far, the imports are at the top
level, so they will be executed on both occasions. I can't think of
any reason why an import would fail when the script is run initially
but then work when the script is re-invoked from g.parser.
Can you add commands to print sys.argv and sys.path (and, if you can
import "os", os.environ) to the top of the script, and see what is
changing before and after g.parser.
I'm not sure I understand. The structure is a 'standard GRASS script'
for Python.
#!/usr/bin/python
At this point, put:
import sys
print sys.argv
print sys.path
import os
print os.environ
GRASS 7.0.svn (Spearfish60_test):~ > histogram_mpldemo.py
********* sys.argv ***********
/Applications/Grass/GRASS-7.0.app/Contents/MacOS/scripts/histogram_mpldemo.py
********* sys.path ***********
/Library/Python/2.5/site-packages/GDAL-1.5.2-py2.5-macosx-10.5-i386.egg
/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/python
/Users/cmbarton
/usr/local/lib/wxPython-unicode-2.8.8.1/lib/python2.5/site-packages
/usr/local/lib/wxPython-unicode-2.8.8.1/lib/python2.5/site-packages/wx-2.8-mac-unicode
/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python25.zip
/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5
/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-darwin
/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac
/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac/lib-scriptpackages
/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python
/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-tk
/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-dynload
/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python/PyObjC
********* os.environ ***********
_
HISTFILE
GRASS_FONT
GRASS_HTML_BROWSER
TERM_PROGRAM_VERSION
CVS_RSH
GRASS_SH
USER
HOME
PATH
GRASS_GNUPLOT
DISPLAY
TERM_PROGRAM
LANG
GRASS_ADDON_PATH
TERM
Apple_PubSub_Socket_Render
INFOPATH
SHLVL
SECURITYSESSIONID
GRASS_PAGER
HISTSIZE
EDITOR
MANPATH
GISBASE
CVSROOT
TK_LIBRARY
GRASS_PERL
PYTHONPATH
SSH_AUTH_SOCK
GRASS_HTML_BROWSER_MACOSX
TCL_LIBRARY
DYLD_LIBRARY_PATH
PWD
SHELL
GRASS_XTERM
GRASS_ADDON_ETC
GRASS_OS_STARTUP
TMPDIR
PERL5LIB
GRASS_LD_LIBRARY_PATH
GRASS_PROJSHARE
GRASS_PYTHON
__CF_USER_TEXT_ENCODING
GRASS_WISH
GISRC
GRASS_TCLSH
GRASS_VERSION
GRASS_FONT_CAP
LOGNAME
GIS_LOCK
COMMAND_MODE
File "/Applications/Grass/GRASS-7.0.app/Contents/MacOS/scripts/histogram_mpldemo.py", line 104, in <module>
import matplotlib
ImportError: No module named matplotlib
This works fine if I type the following on at the GRASS command prompt
before executing
PYTHONPATH="/Library/Frameworks/Python.framework/Versions/2.5/lib/
python2.5/site-packages"$PYTHONPATH
There ought to be a colon between the literal and $PYTHONPATH.
Typo in the email. It is usually there.
Unless it's started with the -S switch, the Python interpreter
performs an automatic "import site". This module adds the
site-packages directory to sys.path; it also adds each subdirectory
which is named in one fo the site-packages/*.pth files.
site — Site-specific configuration hook — Python 3.12.7 documentation
It shoudn't be necessary for PYTHONPATH to be set unless you need to
use modules which aren't installed in Python's lib directory.
Are any of the other PYTHON* environment variables set? If
$PYTHONSTARTUP is set, that could cause an interactive interpreter to
behave differently from a script.
Not that I've set anywhere. $PYTHONSTARTUP is not set.
You could try starting python with and without the -S flag, printing
sys.path in each case. It's possible that there's some oddity in your
setup that is causing site.py to misbehave.
with -S does not have any site-packages; without -S has site-packages. See below.
GRASS 7.0.svn (Spearfish60_test):~ > python
Python 2.5.2 (r252:60911, Feb 22 2008, 07:57:53)
[GCC 4.0.1 (Apple Computer, Inc. build 5363)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import sys
>>> print '\n'.join(sys.path)
/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/Dabo-0.8.3-py2.5.egg
/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/setuptools-0.6c8-py2.5.egg
/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/ipython-0.8.4-py2.5.egg
/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/numpy-1.1.0-py2.5-macosx-10.3-i386.egg
/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/matplotlib-0.98.1-py2.5-macosx-10.3.egg
/Users/cmbarton
GRASS 7.0.svn (Spearfish60_test):~ > python -S
>>> import sys
