I am testing some changes in Python library on Windows and when I get over the current problem, I run into that I can’t import win32file in core/gcmd.py. Some problem with packaging?
Thank you,
Anna
Thank you,
Anna
Related to wingrass, I committed some changes in script/core.py which might break something because I can’t test it properly on Windows, but hopefully it will fix some issues
On Wed, May 15, 2019 at 12:44 PM Anna Petrášová <kratochanna@gmail.com> wrote:
Thank you,
Anna
Anna Petrášová wrote
the current problem, I run into that I can't import win32file in
core/gcmd.py. Some problem with packaging?Thank you,
Anna
grass-dev mailing list
grass-dev@.osgeo
winGRASS 7.7.svn standalone or OSGeo4W-winGRASS7.7.svn?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
standalone
Anna
grass-dev@.osgeo
best regards
HelmutSent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
standalone
trying here with OSGeo4W-winGRASS7.7.svn
C:\>grass77svn ---text D:\grassdata\nc_spm_08_grass7\user1
Starting GRASS GIS...
WARNUNG: Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows
nicht möglich.
Cleaning up temporary files...
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS GIS 7.7.svn (r74474M)
GRASS GIS homepage: https://grass.osgeo.org
This version running through: Command Prompt
(C:\WINDOWS\system32\cmd.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
See citation options with: g.version -x
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching <wxpython> GUI in the background, please wait...
Microsoft Windows [Version 10.0.17763.475]
(c) 2018 Microsoft Corporation. Alle Rechte vorbehalten.
C:\>g.version --help
Displays GRASS GIS version info.
Benutzung:
g.version [-cxbreg] [--help] [--verbose] [--quiet] [--ui]
Schalter:
-c Gebe auch die Copyright-Informationen aus
-x Print also the citation options
-b Print also the build information
-r Print also the GIS library revision number and date
-e Print also extended info for additional libraries
-g Gebe Info im Shell-Skript-Style aus (inklusive SVN Revisionsnummer)
C:\>python
Python 3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:59:51) [MSC v.1914 64 bit
(AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
import sys
import win32com.client as win32
import win32api
import win32file
pywin32 and related things seems to work here.
are the related python packages in the bundled python
(Python37\lib\site-packages\win32)?
best regards
Helmut
standalone
C:>grass77svn —text D:\grassdata\nc_spm_08_grass7\user1
Starting GRASS GIS…
nicht möglich.
Cleaning up temporary files…
/ / __ / | / / / / __/ / /
/ / __/ // / /| | _ \ \ / / __ / / _
/ // / , / ___ |/ // / / // // / / /
_// |// |/// _///_/Welcome to GRASS GIS 7.7.svn (r74474M)
When ready to quit enter: exitLaunching GUI in the background, please wait…
(c) 2018 Microsoft Corporation. Alle Rechte vorbehalten.C:>g.version --help
Displays GRASS GIS version info.Benutzung:
g.version [-cxbreg] [–help] [–verbose] [–quiet] [–ui]Schalter:
-g Gebe Info im Shell-Skript-Style aus (inklusive SVN Revisionsnummer)C:>python
(AMD64)] on win32
Type “help”, “copyright”, “credits” or “license” for more information.import sys
import win32api
import win32file#########################
no, win32 was not there as far as I remember
best regards
applied locally your commits (r74480), I get:
C:\>grass77svn --text
nicht möglich.
Start the GUI with: g.gui wxpython
C:\>g.gui wxpython
Starte <wxpython> GUI im Hintergrund. Bitte warten Sie ...
C:\OSGEO4~1\apps\grass\grass77/gui/wxpython/wxgui.py:101:
DeprecationWarning: Yield() is deprecated
wx.Yield()
File "C:\OSGEO4~1\apps\grass\grass77/gui/wxpython/wxgui.py", line 106, in
OnInit
workspace=self.workspaceFile)
File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\lmgr\frame.py", line
131, in __init__
self._moduleTreeBuilder =
LayerManagerModuleTree(message_handler=add_menu_error)
File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\lmgr\menudata.py", line
68, in __init__
message_handler=message_handler)
File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\menutree.py", line
71, in __init__
xmlTree = etree.parse(filename)
File "C:\OSGEO4~1\apps\Python37\lib\xml\etree\ElementTree.py", line 1197,
in parse
tree.parse(source, parser)
File "C:\OSGEO4~1\apps\Python37\lib\xml\etree\ElementTree.py", line 598,
in parse
self._root = parser._parse_whole(source)
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
OnInit returned false, exiting...
best regards
Helmut
Did you compile it with those local changes? It needs to be compiled to create the xml files.
core/gcmd.py. Some problem with packaging?applied locally your commits (r74480), I get:
C:>grass77svn --text
Starting GRASS GIS…
nicht möglich.
When ready to quit enter: exitMicrosoft Windows [Version 10.0.17763.475]
(c) 2018 Microsoft Corporation. Alle Rechte vorbehalten.C:>g.gui wxpython
Starte GUI im Hintergrund. Bitte warten Sie …
wx.Yield()
File “C:\OSGEO4~1\apps\grass\grass77/gui/wxpython/wxgui.py”, line 106, in
OnInit
File “C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\lmgr\frame.py”, line
131, in init
File “C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\lmgr\menudata.py”, line
68, in init
File “C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\menutree.py”, line
71, in init
File “C:\OSGEO4~1\apps\Python37\lib\xml\etree\ElementTree.py”, line 1197,
in parse
File “C:\OSGEO4~1\apps\Python37\lib\xml\etree\ElementTree.py”, line 598,
in parse
OnInit returned false, exiting…
best regards
(Python37\lib\site-packages\win32)?no, win32 was not there as far as I remember
looking at
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/osgeo4w/setup_x86_64.hint.tmpl
requires: liblas avce00 gpsbabel gs python3-gdal python3-matplotlib msvcrt
msvcrt2013 msvcrt2015 iconv libtiff gdal proj pdcurses zlib fftw libpng
python3-wx python3-numpy python3-pillow python3-pip python3-ply
python3-pyopengl cairo python3-psycopg2 python3-six rbatch zstd zstd-bin
python3-pywin32 <=
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/osgeo4w/setup_x86.hint.tmpl
msvcrt2013 msvcrt2015 iconv libtiff gdal proj freetype-mingw pdcurses zlib
fftw libpng python3-wx python3-numpy python3-pillow python3-pip python3-ply
python3-pywin32
there is pywin32 as a requirement for winGRASS.
comparing the OSGeo4W python3
C:\OSGeo4W64\apps\Python37\lib\site-packages\win32\
and a win32file inside
with a just downloaded
https://wingrass.fsv.cvut.cz/grass77/x86_64/WinGRASS-7.7.svn-r74475M-23-Setup-x86_64.exe
WinGRASS-7.7.svn-r74475M-23-Setup-x86_64\$_93_\Python37\Lib\site-packages
there is no win32-site package inside.
it's an package issue.
best regards
Helmut
no compilation yet, just copied the updated python script.
which is the relevant xml-file?
best regards
Helmut
looking at
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/GRASS-Packager.bat.tmpl#L98
96 @echo.
97 @echo
98 @echo Copy Python content to PACKAGE_DIR\Python37
99 @echo
100 @echo.
101
102 mkdir %PACKAGE_DIR%\Python37
103
104 xcopy %OSGEO4W_PKG_DIR%\apps\Python37\* %PACKAGE_DIR%\Python37 /S/V/F/I
the OSGeo4W-package environment on Martin's build server has to be upated to
include pywin32.
best regards
Helmut
create the xml files.no compilation yet, just copied the updated python script.
it creates gui/wxpython/xml/menudata.xml and module_tree_menudata.xml during compilation.
best regards
during compilation.
module_tree_menudata.xml is empty here. I have to wait for the next daily
build to test.
best regards
Helmut
during compilation.module_tree_menudata.xml is empty here. I have to wait for the next daily
build to test.
daily winGRASS trunk is at r74479-24, so 1 behind r74480: pythonlib: cleanup
decoding/encoding in scripting library
let's see the next daily build
best regards
Helmut
hellik@
during compilation.
now self compiled winGRASS
nicht möglich.
Welcome to GRASS GIS 7.7.svn (r74506M)
module_tree_menudata.xml is still empty after compilation
best regards
Helmut
