Yes - it's a work in progress still. SAGA algs are being worked on in https://github.com/qgis/QGIS/pull/5021, we need someone to step up and
port the GRASS ones. GDAL still has a few left to port (volunteers
welcome), but the QGIS ones are 97% there (I'll do the remainder of
those).
We desperately NEED more people to step up and help here. In the worst
case scenario (no-one ports grass or the remaining GDAL algs) I'll
have to resort to reverting all the c++ processing improvements OR
have duplicate "processingv2" plugin type approach (with only the
ported algs, and a duplicate "processing v1" 2.x style plugin).
Yes - it’s a work in progress still. SAGA algs are being worked on in https://github.com/qgis/QGIS/pull/5021, we need someone to step up and
Does anyone know the current state of GRASS GIS support in QGIS3?
On Oct 22, 2017 10:45 AM, “Jürgen E. Fischer” <jef@norbit.de> wrote:
Hi Markus,
GRASS support is still completely disabled in processing. Feature freeze for 3
is next friday.
Ouch.
Any pointers what to do here?
Unfortunately I’m not able to also follow QGIS-dev.
I thought someone was talking care, I read a related email some time ago.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
On Oct 22, 2017 10:45 AM, "Jürgen E. Fischer" <
jef@
> wrote:
Hi Markus,
for 3
is next friday.
Ouch.
Unfortunately I'm not able to also follow QGIS-dev.
for 3 is next friday.
Ouch.
Ouch.
neteler@
hellik@
freeze
Ouch.
ago.
Default region was updated to the new projection, but if you have
multiple mapsets `g.region -d` should be run in each to update the region
from the default
