On Mon, Oct 5, 2015 at 11:16 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
On Mon, Oct 5, 2015 at 1:16 PM, Radim Blazek <radim.blazek@gmail.com> wrote:
>> There is v.build.all in modules.
> yes, but the user has no hint about its necessity; further steps:
> db.connect -d
> v.db.reconnect.all -cd
> are not available among modules (BTW, maybe these options could be added
> to existing modules?).
Building broken topology from browser can be always useful, but I
don't think that browser/plugin must have UI for upgrading GRASS data
from 6 to 7, something which has to be rarely done and which should be
done with understanding (upgrade from dbf to sqlite).
Perhaps a special plugin. Do you think it would be a good idea to have
plugins based on the GRASS plugin? (They would probably just call modules
but in the way GRASS plugin does.)
I have added qgis.v.upgrade.py which runs
v.build.all
db.connect -d
but v.db.reconnect.all fails with -d even from GRASS shell:
Reconnecting vector map <lines@upgrade> (1 of 3)...
Copying table <lines> to target database...
File "grass-7.1.svn/scripts/db.droptable", line 99, in <module>
main()
File "grass-7.1.svn/scripts/db.droptable", line 77, in main
used = grass.db.db_table_in_vector(table)
File "grass-7.1.svn/etc/python/grass/script/db.py", line 189, in
db_table_in_vector
for f in vector_db(vect, stderr=nuldev).itervalues():
File "grass-7.1.svn/etc/python/grass/script/vector.py", line 46, in vector_db
**args)
File "/grass-7.1.svn/etc/python/grass/script/core.py", line 460, in
read_command
return handle_errors(returncode, stdout, args, kwargs)
File "grass-7.1.svn/etc/python/grass/script/core.py", line 328, in
handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['v.db.connect',
'--q', '-g', 'map=edit@PERMANENT', 'sep=;'] ended with error
Process ended with non-zero return code 1. See errors in the (error) output.
ERROR: Unable to drop table <lines>
> db.connect -d
v.build.all
db.connect -d
main()
db_table_in_vector
**args)
read_command
handle_errors
>> > db.connect -d
added
v.build.all
db.connect -d
main()
db_table_in_vector
vector_db
**args)
read_command
handle_errors
output.
Hi Radim,
it works for me with NC sample Location for G6 [1]. So, the same as for
Paolo [2]. How can I reproduce it? I've tried vector map without a table,
but it also worked well. Tested with latest 7.0 release branch code.
