Hi there
2015-10-27 16:30 GMT-03:00 Pedro Venâncio <pedrongvenancio@gmail.com>:
I did. And I got it working!! So, grass7 plugin is not in qgis 2.12.0-1, but it is there in qgis-rel-dev 2.12.0-3
Thank you so much for your help, Padro! And all!
Vero
ps: i’m also copying grass-dev for record
I’ve installed grass and qgis (2.12) from the osgeo4w installer 32 bits (https://trac.osgeo.org/osgeo4w/), using “Advance install”. To get grass plugin, I also selected from Libs:
qgis-grass plugin (for grass64)
qgis-grass plugin common
qgis-grass plugin7 (for grass7)Both, testing with grass7.0.2RC1-1 and grass7.0.1-1, I do not find grass plugin in Plugin → Manage and Install Plugins. Using QGIS with grass64 works fine and plugin is there, though.
I confirm this.
I’ve installed
qgis-dev 2.13.0-3
and I get GRASS 7 plugin working properly, using grass 7.0.1-1 and running qgis-rel-dev-g7.0.1.bat and qgis-dev-g7.0.1.bat, respectively.
I also installed qgis 2.12.0-1 (qgis: QGIS Desktop), and running qgis-grass7.bat, I don’t have the GRASS 7 plugin.
Moreover, if I try to uninstall grass I get:
grass (7.0.2RC1-1)
GRASS GIS - stable release
Required by: qgis-dev, qgis-grass-plugin7, qgis-rel-dev
So, it seems that it is not a dependency for 2.12.0-1, which leads to suspect that this version was not compiled with grass 7. Am I wrong?
Veronica, please install qgis-rel-dev 2.12.0-3 instead of qgis 2.12.0-1.
