I got the following mail today about QGIS 0.9.0 (I assume the
preview version) on Windows:
On Tue, Oct 23, 2007 at 01:16:44PM +0200, El. wrote:
I have a quick question for you, I have installed QGIS 0.9.0 Ganymede on a
Vista computer (from a colleague) and contrarily to what I have
experienced on my PC (no problems whatsoever), we seem to have a problem
when we want to create dbf files.
eg using v.in.ogr or v.in.db
Each time we get the following error message:v.in.ogr dsn=C:\training\exercise3\rivers.shp output=gr_rivers -o
Over-riding projection check
Layer: rivers
Invalid argument: can't _spawnl
Cannot open driver 'dbf'
Cannot open database C:/EpiGIS/grassworkingdir/Kenyadata/Els/dbf/ by
driver dbfFinished with error
And we are not able to solve it. I have tried using the mingw shell but to
no avail. I have also copied my directory structure, which works fine on
my pc to hers but also no solution. We have created the dbf dir by hand
but also no solution....
This is probably related to the fact that winQGIS 0.9 preview AFAIK contains
a GRASS 6.2 copy. Could this be fixed later on (hence, we want 6.3.0 to be
packaged)?
