[GRASS-dev] QGIS GRASS Plugin Upgrade Crowdfunding
I have finally launched the crowdfunding campaign to support the GRASS
plugin upgrade. Briefly, it covers upgrade to GRASS 7, browser
integration, drag-and-drop import and new vector editing. All the
details are available here:
    http://www.gissula.eu/qgis-grass-plugin-crowdfunding/
Please propagate this info to all relevant channels, national mailing lists etc.
Radim
Hi Radim,
this is a beautiful idea and i hope you will get plenty of funds.
I have some questions regarding the implementation, since this is not
mentioned in the project description:
Do you plan to implement the plugin in C++ only, or will you try to
combine C++ (data provider) and Python (all the rest)? The reason i am
asking is, that using Python for the user interaction, module calling,
vector editing and mapset/location handling would allow us GRASS
developer to provide possible improvements and bugfixes for the plugin
more easily. For example, the time series handling [1] in GRASS GIS is
mainly implemented in Python and provides a Python API that could be
used in the QGIS GRASS Plugin to implement time series analysis
support.
Using the QGIS Python plugin approach will reduce the need for
compilation, which allows much faster development of modifications and
bugfix testing.
The data provider and vector editing helper classes must be of course
implemented in C++ and should stay in the QGIS source tree.
Best regards
Soeren
[1] http://ifgi.uni-muenster.de/~epebe_01/tgrass.pdf
Btw: Otto Dassau and i mentioned your crowd funding idea at the
FOSSGIS in Germany two weeks ago. It is on Youtube[2] but only in
German.
[2] https://www.youtube.com/watch?v=rxmPbh2igmM&t=1407
2015-03-23 19:56 GMT+01:00 Radim Blazek <radim.blazek@gmail.com>:
Radim
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Radim,
together with Francesco Geri, last week we started to write a first
draft that generate the GUI for the GRASS module dynamically (based on
the xml generated with: --interface-description), so far it is based
on grass7 but should work also on grass6 (not tested, should be enough
to backport the pygrass.modules.Module class).
Best regards
Pietro
On Mon, Mar 23, 2015 at 7:56 PM, Radim Blazek <radim.blazek@gmail.com> wrote:
Radim
Hi Soeren,
thanks for your reaction. I remember we already discussed the
possibility to move to Python.
On Mon, Mar 23, 2015 at 9:19 PM, Sören Gebbert
<soerengebbert@googlemail.com> wrote:
Hi Radim,
support.
bugfix testing.
I completely agree that Python would be better, the advantages of
Python are obvious and that would be definitely my choice if I had to
start from scratch. Un(fortunately) the GRASS plugin + qgsgrassgislib
have already 22500 lines of C++ so porting to Python is not an option
and mixing C++ in single plugin either (as far to my knowledge).
Are there functions in time series implementation which need to be
called directly from the plugin or everything may be done just calling
t.rast.* modules?
Radim
Best regards
Soeren
German.
Radim
Hi Radim,
2015-03-24 9:40 GMT+01:00 Radim Blazek <radim.blazek@gmail.com>:
Hi Soeren,
Hi Radim,
support.
bugfix testing.
Indeed, porting the C++ code to Python is a large effort. However,
maybe you can define a stretch-goal in the crowd funding campaign? If
this goal is met, then you have enough funds to port the C++ code to
Python and you can add more features?
I think that using C++ and Python in a Plugin shouldn't be a big
problem in my humble opinion. The main issue would be that the C++
code of the data provide will be part of QGIS and the Python code that
makes use of the GRASS data provider will be a separate GRASS Python
QGIS plugin. Maybe this approach will allow to implement several
independent Python plugins that make use of the GRASS data provider to
implement specific algorithms?
t.rast.* modules?
Most of the temporal functionality is available through the temporal
modules. However some important algorithms (temporal re-sampling) are
available only in the Python framework. This is needed for time series
animation creation. Using the framework directly will speed things up,
because the module calls, the parsing and interpretation of the module
outputs can be avoided.
Many thanks for the QGIS GRASS Plugin
Best regards
Soeren
Radim
Best regards
Soeren
German.
Radim
Hi Soeren
On Tue, Mar 24, 2015 at 10:04 AM, Sören Gebbert
I don't have any serious estimation how much porting from C++ to
Python costs, but new line of code costs 10-50euro (according to quick
internet search). To be really very modest, say that porting would
cost 2 euro per line, i.e. 22500*2 = 45000 euro for somethings which
brings no new features to users. That is not something I would ever
propose.
QGIS plugin.
The plugin and the provider are sharing some C++ code (qgsgrass and
qgsgrasslib). To port the plugin to Python you also have to write and
maintain Python bindings for that shared classes which is just extra
work.
That should not depend on the GRASS plugin in C++. If you write Python
bindings for the provider, you can use it (non standard) in your
Python plugin. I believe however that plugins implementing algorithms
should be preferably provider independent.
t.rast.* modules?
If it should be used for dynamic animation in QGIS canvas you could
consider the possibility to subclass raster renderer in Python and
insert it into raster layer pipe from Python plugin.
German.
Thank you a lot!
Radim
On Tue, Mar 24, 2015 at 5:56 AM, Radim Blazek <radim.blazek@gmail.com>
>> t.rast.* modules?
Speaking about animations, some things from GRASS GIS GUI could be perhaps
used directly in the same was as Tcl/Tk NVIZ is used in processing for
GRASS 6. Animation tool is one of them. This would be great since we would
get al least some functionality/code sharing between GRASS and QGIS GUIs
which is otherwise not possible due to Python/wxPython and C++/Qt (and
would be only possible if both things would be at least in the same
language).
This is of course not fulfilling the requirement to be general, i.e. work
with other data providers in QGIS, but surely some things just have to be
like that if they are using GRASS-specific formats (temporal data) or
algorithms (e.g. algorithms to work with temporal data, their topology,
Vaclav
On Tue, Mar 24, 2015 at 2:00 AM, Pietro <peter.zamb@gmail.com> wrote:
Hi Radim,
Hi Pietro and Francesco,
this sounds good. Are you speaking about QGIS GUI (in Python) generated
from --interface-description? Do you think it would be possible to write it
in a way which would be GUI framework independent so that it is usable in
both GRASS and QGIS? The GUIs for modules in GRASS are quite good now but
the code should be rewritten and this would be a great way how to get this
new implementation.
Vaclav
Best regards
Pietro
wrote:
> Hi all,
lists etc.
> Radim
On Tue, Mar 24, 2015 at 7:00 AM, Pietro <peter.zamb@gmail.com> wrote:
Hi Radim,
The GUI for GRASS module in the plugin is also generated based on
--interface-description, qgm files are only used to define a subset of
module's options or to override option attributes (like label) if
necessary. So it is already implemented, but always combined with qgm,
skipping qgm, it maybe used to generate generic UI for any module.
Using qgm gives more power, for example table field combo options
based on current layer selected as input, setting input type from
input layer, selecting feature categories in map canvas and so on.
You may be interested in
https://github.com/qgis/QGIS/blob/master/src/plugins/grass/qgsgrassmodule.cpp
Do you see a possibility how we could join the effort?
Radim
Best regards
Pietro
Radim
Hi Vaclav,
this sounds good. Are you speaking about QGIS GUI (in Python) generated from
--interface-description? Do you think it would be possible to write it in a
way which would be GUI framework independent so that it is usable in both
GRASS and QGIS? The GUIs for modules in GRASS are quite good now but the
code should be rewritten and this would be a great way how to get this new
implementation.
yes, actually what I wrote it is completely independent from QGIS, it
is compatible with pyqt/pyside and with python2/python3,
It is just a proof of concept. Now Francesco it is working to better
integrate this draft with QGIS stuff.
The idea was heavily based on formlayout code:
https://code.google.com/p/formlayout/
Basically each parameter is a GUI field that it is add to the main
window, therefore based on the parameter type the field could be:
if "raster"/"vector" => a combo box with the rasters/vectors available
if "integer" => a spinbox
if "string"/"double" => a text field
if "file" => a file dialog
based on the guisection parameter all the options are organized in tabs.
The code is under 500 lines of code.
I guess should be possible to follow the same approach using the wxpython.
I think that with a bit more effort should be possible to make it
general enough to make it independent from the GUI framework (Qt/Wx)
that we want to use.
I have not link to share at this stage because we are still working on it.
But I guess we can share the code as soon as we have something that it
is able to cover the basic needs.
Pietro
Hi Radim,
On Tue, Mar 24, 2015 at 5:11 PM, Radim Blazek <radim.blazek@gmail.com> wrote:
necessary. So it is already implemented, but always combined with t,
Yes I know that that there was this tool already available, but we
want to build something that use only the --interface-description, to
avoid to synchronize the qgm file for each change that we made on the
grass-addon.
I would love to join the effort, the main problem here is that I don't
know cpp, therefore I can not play actively on this side.
However I think that some extra fields in the xml description are
missing and should be add to easily go on the direction of the
dynamically generated GUI.
But I will open a new thread.
Pietro
On Tue, Mar 24, 2015 at 1:30 PM, Pietro <peter.zamb@gmail.com> wrote:
Hi Vaclav,
from
in a
new
> implementation.
That's good to hear.
Both QGIS and GRASS are adding different extra features like setting region
according to a selected raster or dependent fields for vector GRASS layers
and attributes. That's why it gets complicated at the end. And of course
then there is the extra information which is not stored in XML such as
"GRASS standard options".
Anyway, skipping qgm is quite important feature for QGIS since it is
necessary for GRASS addons as you say.
I'm looking forward to that.
Pietro
Dear all,
just a short reminder. The crowd funding period for the QGIS GRASS
Plugin is still running but will end soon. Everyone who may be
willingly to fund this great project can contribute funds until May
23.
Best regards
Soeren
Radim
On Mon, May 18, 2015 at 2:22 PM, Sören Gebbert
Dear all,
23.
BTW, raster/vector import via browser is in master (pushed today), you can test.
Dual build (with GRASS 6 + 7) is also available. Big thanks to Jef for
porting dual build to Windows.
Currently there is unfortunately some problem in browser with GRASS 7
vectors (crash), but GRASS 7 vectors load correctly from project file
(e.g. project created in GRASS 6, vectors upgraded to GRASS 7 and
project reopened in QGIS with GRASS 7).
I'll do more detailed announcement after QGIS 2.10 freeze.
Radim
Best regards
Soeren
Radim
Hi all.
The project is funded! Thanks to everybody who contributed or promoted
the project.
The first two parts are implemented, you can follow the work progress here:
  http://www.gissula.eu/qgis-grass-plugin-crowdfunding/progress.html
browser demo video:
  https://www.youtube.com/watch?v=5d1jZzyRyRY
Many thanks to Jef for the help with dual build port to Windows, which
saved me a lot of headache and for patient fixing of the bugs I
introduced on Windows.
You can now build QGIS with GRASS 6, 7 or both. For the GRASS 7, there
are three new cmake options: WITH_GRASS7, GRASS_INCLUDE_DIR7,
GRASS_PREFIX7. Libs and binaries for each version have GRASS major
version number appended to file names. You can choose the version of
provider/plugin on runtime setting LD_LIBRARY_PATH to the directory
where GRASS libs are installed. For example:
LD_LIBRARY_PATH=/home/user/apps/grass-6.4.4/lib /home/user/apps/bin/qgis
Similarly, there are bat files in OSGEO4W 32bit for each GRASS version
(GRASS 7 is not dependency and must be selected manually). There is no
GRASS 7 provider in OSGEO4W 64bit, because there is no GRASS 7 in
OSGEO4W 64bit yet.
Please test but be aware that there are still many issues, especially
on Windows which I hope to fix for QGIS 2.10 release.
Radim
Hi Radim,
Is this why my QGis crashes when i try to load a Grass 7.0 vector file? [1]
Thanks
Daniel
[1] - http://gis.stackexchange.com/questions/138477/loading-grass-7-0-vectors-in-qgis-broken
On Tue, Mar 24, 2015 at 11:47 AM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
grass-user mailing list
grass-user@lists.osgeo.org
On Tue, Mar 24, 2015 at 5:56 AM, Radim Blazek <radim.blazek@gmail.com> wrote:
t.rast.* modules?
Speaking about animations, some things from GRASS GIS GUI could be perhaps used directly in the same was as Tcl/Tk NVIZ is used in processing for GRASS 6. Animation tool is one of them. This would be great since we would get al least some functionality/code sharing between GRASS and QGIS GUIs which is otherwise not possible due to Python/wxPython and C++/Qt (and would be only possible if both things would be at least in the same language).
This is of course not fulfilling the requirement to be general, i.e. work with other data providers in QGIS, but surely some things just have to be like that if they are using GRASS-specific formats (temporal data) or algorithms (e.g. algorithms to work with temporal data, their topology, …).
Vaclav
On Tue, Mar 24, 2015 at 5:31 PM, Daniel Victoria
<daniel.victoria@gmail.com> wrote:
Hi Radim,
AFAIC, it should only crash if you try to open a GRASS mapset with
GRASS 6 vectors in QGIS browser compiled and run with GRASS 7
provider. It is described here:
http://lists.osgeo.org/pipermail/qgis-user/2015-March/031177.html
I think that I know already what the problem is. If GRASS 7 lib is
tries to open a vector which it is not in format 7, it calls
G_fatal_error(), which normally opens a warning dialog. Because items
in the browser are populated in threads, it happens on non GUI thread,
but to open a dialog with an icon, it has to use QIcon which can only
be used on GUI thread.
Radim
Thanks
Daniel
[1] -
>> t.rast.* modules?
Vaclav
Hi Radim,
I’m using grass 7 and QGis installed from OSGeo4Win so maybe it was compiled against some old libraries? I’ve no idea how to compile in windows so I’ll just try to re-install everything and hope things work…
Daniel
On Tue, Mar 24, 2015 at 4:18 PM, Radim Blazek <radim.blazek@gmail.com> wrote:
Hi Radim,
Radim
Thanks
Daniel
[1] -
t.rast.* modules?
Vaclav
On Wed, Mar 25, 2015 at 12:44 AM, Daniel Victoria
Hi Radim,
I'm using grass 7 and QGis installed from OSGeo4Win so maybe it was compiled
against some old libraries? I've no idea how to compile in windows so I'll
just try to re-install everything and hope things work...
QGis from OSGeo4Win is compiled with GRASS 6, you cannot get it
working with GRASS 7. Reinstalling will not help. The provider and the
plugin has first to be fixed to support build with both GRASS 6 and
GRASS 7. This is in the first package of proposed upgrade:
Then a bat to start QGIS with GRASS 7 could be added also to OSGeo4Win.
Radim
Daniel
> Hi Radim,
> [1]
Radim
> Thanks
> Daniel
> [1] -
>>> >> calling
>>> >> t.rast.* modules?
>>> > are
>>> > series
>>> > up,
>>> > module
>> perhaps
>> GRASS
>> get al
>> is
>> only
>> work
>> be
>> Vaclav
>> _______________________________________________
