bringing this to your attention - perhaps some help could
be provided.
---------- Forwarded message ----------
Date: Mon, Jan 11, 2010 at 10:39 PM
Subject: Re: [Quantum GIS] #1095: 3-D GRASS line vectors from
r.contour - Cant query or identify the lines, but can label the
attributes
To:
Cc: qgis-trac@lists.osgeo.org
#1095: 3-D GRASS line vectors from r.contour - Cant query or identify the lines,
but can label the attributes
Reporter: dadudeman | Owner: rugginoso
Type: defect | Status: closed
Priority: major: does not work as expected | Milestone:
Version 1.0.3
Component: GRASS | Version: HEAD
Resolution: fixed | Keywords:
3D line vector, cant query identify
Platform_version: Kubuntu 7.1 | Platform: Linux
Must_fix: Yes | Status_info: 0
Changes (by rblazek):
* status: new => closed
* resolution: => fixed
Comment:
Yes, bug, I have fixed it in QGIS changeset:12738 but it is not perfect.
QGIS is using Vect_select_lines_by_polygon and it is selecting lines using
bbox of the passed polygon. I have just set z coors to
-PORT_DOUBLE_MAX/PORT_DOUBLE_MAX to cover 3D. It should be better
specified in GRASS how Vect_select_lines_by_polygon treats 3D vectors, but
until they touch the function, it works in QGIS.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1095#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR,
PostGIS, and GRASS formats
