[GRASS-dev] question about error in r.watershed
I am running the new r.watershed (SVN from 10 December) and got an error in calculating the ls factor.
r.watershed elevation=elevation.dem@PERMANENT length.slope=atest_rs_ls memory=300
ERROR: /Applications/GRASS-6.4.app/Contents/MacOS/etc/r.wate
rshed.ram [-4] el=elevation_map t=swale_threshold
[dr=drain_direction_map] [de=depression_map]
[ac=accumulation_map] [di=display_map] [ms=max_slope_length]
[ob=overland_blocking_map] [S=slope_steepness_map]
LS=length_slope_map [r=rill_erosion_map]
[sd=slope_deposition value or map]
Subprocess failed with exit code 256
category information for [atest_rs_ls] in [PERMANENT]
missing or invalid
Am I doing something wrong, or is this a bug?
Michael
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
r.watershed elevation=elevation.dem@PERMANENT length.slope=atest_rs_ls memory=300 ERROR: /Applications/GRASS-6.4.app/Contents/MacOS/etc/r.wate
missing or invalid
This is a bug. If you specify length.slope you must give a basin threshold value.
Running
r.watershed elevation=elevation.dem@PERMANENT length.slope=atest_rs_ls threshold=3000
works.
This is not caught in front/main.c, I will supply a patch
The fix would be to add the following lines in front/main.c at line 223
    /* LS factor and basin.thresh */
    err += (opt14->answer != NULL && opt6->answer == NULL);
Markus M
Markus,
I applied your patch and got the following compiler error:
cmb-MBP-2:r.watershed cmbarton$ make
make -C ram || echo /Users/cmbarton/grass_dev/grass6_src/raster/r.watershed/ram >> /Users/cmbarton/grass_dev/grass6_src/error.log
Makefile:13: warning: overriding commands for target `htmletc'
../../../include/Make/Html.make:53: warning: ignoring old commands for target `htmletc'
make htmletc
No docs to generate.
make -C seg || echo /Users/cmbarton/grass_dev/grass6_src/raster/r.watershed/seg >> /Users/cmbarton/grass_dev/grass6_src/error.log
make htmletc
make -C front || echo /Users/cmbarton/grass_dev/grass6_src/raster/r.watershed/front >> /Users/cmbarton/grass_dev/grass6_src/error.log
gcc -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.6.0/include -arch i386 -Os -DPACKAGE=\""grassmods"\" -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.6.0/include -o OBJ.i386-apple-darwin9.6.0/main.o -c main.c
main.c: In function ‘main’:
main.c:224: error: stray ‘\202’ in program
make[1]: *** [OBJ.i386-apple-darwin9.6.0/main.o] Error 1
missing or invalid
Running
works.
Markus M
> 223
main.c: In function �main�:
main.c:224: error: stray �\202� in program
Presumably, that's in the line you added.
I suspect an error in the copy/paste from the email. I've attached
Markus' suggested change as a binary attachment.
(attachments)
r.watershed.patch (588 Bytes)
This worked. Thanks.
Michael
____________________
Phone: 480-965-6262
Fax: 480-965-7671
223
<r.watershed.patch>
Thanks Glynn, I couldn't figure out where this error came from. Patches for this bug: no error if length.slope is requested without giving basin threshold are attached to ticket 398 [1], separately for grass64 and grass70.
Markus M
[1] http://trac.osgeo.org/grass/ticket/398
Michael
Phone: 480-965-6262
Fax: 480-965-7671
223
<r.watershed.patch>
grass-dev mailing list
grass-dev@lists.osgeo.org
