Michael wrote:
I've tested it in wxPython and it works on the Mac.
thanks.
I remember some talk about windows not having a command line.
one is available. just not at the same time as the gui.
from the OSGeo4W DOS box shell run "grass64 -text" and you get one
in the same dos box. (but no xmons) Handy for batch jobs or experts.
But in fact it does have a command line in both TclTk and
wxPython, even if it does not have a full terminal.
[internal one, see "d.mon not implemented" error window from wxPy seen
in i.class thread when a user tries to follow old-way examples]
The lack of a terminal, however, means that text and old d.m are not
available for Windows.
ok, d.m is not available in windows because of no monitors and it uses
xmons. hmm. "d.m" from the command prompt actually does launch it.
(more below)
It only can run the TclTk gis.m and wxPython GUI's.
(and stand-alone text)
I'm not sure what will happen in Windows if someone selects text or
d.m.
If you select text, next time you start grass by double clicking the
desktop icon you get the normal esc-enter screen in the dos box and
text mode.
if you select oldtcltk it opens gis.m and resets the GRASS_GUI setting to
be tcltk. (tcltk is written to be the default fail-over in init.bat)
no -help option either FWTW.
from text mode in a dos box if you type "d.m" at the command line grass
prompt d.m actually loads up. it just gives an error when you try and open
a new monitor for display. from the grass/dos prompt in text mode "g.gui tcltk" or "g.gui wxpython" do nothing.
"python %GISBASE%/etc/wxpython/wxgui.py" from text mode successfully opens
the wxPython GUI.
"gis.m" from the dos prompt gives an error that it doesn't know what to do
with .tcl files -> pick an app dialog. presumably you could associate .tcl
files with wish.exe and then it would open.
Hamish
