I am trying to wrap my head around grass initialization, which unfortunately is not that easy, so bear with me if I ask something stupid.
In grass/script/setup.py
there is a function called set_gui_path()
def set_gui_path():
"""Insert wxPython GRASS path to sys.path."""
gui_path = os.path.join(os.environ['GISBASE'], 'gui', 'wxpython')
if gui_path and gui_path not in sys.path:
sys.path.insert(0, gui_path)
As you can see it has a very specific side-effect, i.e. it adds GISBASE/gui/wxpython
to sys.path
This function was introduced in 67310 and is being called in a bunch of gui/wxpython modules:
gui/wxpython/photo2image/[g.gui.photo2image.py](http://g.gui.photo2image.py)
gui/wxpython/image2target/[g.gui.image2target.py](http://g.gui.image2target.py)
gui/wxpython/gmodeler/[g.gui.gmodeler.py](http://g.gui.gmodeler.py)
gui/wxpython/timeline/[g.gui.timeline.py](http://g.gui.timeline.py)
gui/wxpython/rlisetup/[g.gui.rlisetup.py](http://g.gui.rlisetup.py)
gui/wxpython/vdigit/[g.gui.vdigit.py](http://g.gui.vdigit.py)
gui/wxpython/animation/[g.gui.animation.py](http://g.gui.animation.py)
gui/wxpython/startup/locdownload.py
gui/wxpython/mapswipe/[g.gui.mapswipe.py](http://g.gui.mapswipe.py)
gui/wxpython/dbmgr/[g.gui.dbmgr.py](http://g.gui.dbmgr.py)
gui/wxpython/gcp/[g.gui.gcp.py](http://g.gui.gcp.py)
gui/wxpython/psmap/[g.gui.psmap.py](http://g.gui.psmap.py)
gui/wxpython/mapdisp/main.py
gui/wxpython/mapdisp/test_mapdisp.py
gui/wxpython/iclass/[g.gui.iclass.py](http://g.gui.iclass.py)
gui/wxpython/gui_core/pyedit.py
gui/wxpython/gui_core/goutput.py
gui/wxpython/gui_core/ghelp.py
gui/wxpython/gui_core/forms.py
gui/wxpython/gui_core/treeview.py
gui/wxpython/gui_core/simplelmgr.py
gui/wxpython/datacatalog/[g.gui.datacatalog.py](http://g.gui.datacatalog.py)
gui/wxpython/modules/mapsets_picker.py
gui/wxpython/tplot/[g.gui.tplot.py](http://g.gui.tplot.py)
Nevertheless, if we start the GUI, and check sys.path
in the embedded python console,
we see that GISBASE/gui/wxpython
has been already added to the path; probably due to one of those calls:
>>> import sys
>>> sys.path
['/home/pmav99/Prog/svn/grass_svn/dist.x86_64-pc-linux-gnu/gui/wxpython',
'/home/pmav99/Prog/svn/grass_svn/dist.x86_64-pc-linux-gnu/etc/python',
'/usr/lib/python37.zip',
'/usr/lib/python3.7',
'/usr/lib/python3.7/lib-dynload',
'/home/pmav99/Prog/svn/grass_svn/venv3/lib/python3.7/site-packages',
'/home/pmav99/Prog/svn/grass_svn/dist.x86_64-pc-linux-gnu/etc/r.in.wms'
So if GISBASE/gui/wxpython
is needed to be in sys.path
for the GUI to work correctly, what is the problem with adding it once when the GUI starts and be done with it?
with kind regards,
Panos
