I was wondering if anyone could describe, or point me to a link of, the various r.grow metrics parameter definitions: euclidian, maximum, and manhattan.
Also, are the comments regarding how r.grow decides how to grow between two equally eligible cells here (http://www.nabble.com/-GRASSLIST%3A7611--r.grow-to8629593.html#a8629593) still valid? I would like to add this information to the docs, and AFAICS, main.c hasn't changed much since Glynn's last edit 21505 back in late November, 2006.
~ Eric.
I found some of the metrics explained in wikipedia under Taxicab geometry
Helena
~ Eric.
grass-dev mailing list
grass-dev@lists.osgeo.org
Helena:
Taxicab geometry
see http://article.gmane.org/gmane.comp.gis.grass.devel/2330/
with manhattan AFAIU you can go crosstown or up/downtown but not diagonally through sky-scrapers.
(ignoring the mess of cobblestones below 14th st + broadway
Eric:
to a link of,
euclidian,
still valid? I
don't know. but beware there was r.grow and r.grow2 which worked differently.
Hamish
manhattan.
Euclidean (aka "Pythagoras' theorem"):
d(dx,dy) = sqrt(dx^2 + dy^2)
http://en.wikipedia.org/wiki/Euclidean_metric
Isolines of distance from a point are circles
Manhattan:
d(dx,dy) = abs(dx) + abs(dy)
http://en.wikipedia.org/wiki/Manhattan_metric
Isolines of distance from a point are rhombi (diamonds).
[See Hamish' reply for the reason behind the "Manhattan" name.]
Maximum:
d(dx,dy) = max(abs(dx),abs(dy))
Isolines of distance from a point are squares.
still valid?
Yes.
