[GRASS-dev] Question on the CDHC library
Hi all!
Is there someone tuning in to this list that has knowledge on the content and history of the GRASS library CDHC?
In a recent PR dealing with compiler warnings a strange line of code in Cdhc_enormp() was discussed [1].
It turned out we could not find any documentation on what this function is supposed to do and --more importantly-- that it was not even used. I therefore put up a PR suggesting to remove that function [2], but I wanted to give it a last chance with this post…
I also posted a PR [3] for adding the statlib cdh Fortran source code by Paul Johnson (which the cdhc library code was based upon) to the library documentation.
Best,
Nicklas
[1] https://github.com/OSGeo/grass/pull/2164#discussion_r1014211809
[2] https://github.com/OSGeo/grass/pull/2640
[3] https://github.com/OSGeo/grass/pull/2642
The deafening response on this issue :slight_smile: suggests to me it is safe to remove the unused function 'Cdhc_enormp()’ from the CDHC library.
If there are no objections I will shortly merge the PR:
On 10 Nov 2022, at 15:39, Nicklas Larsson <n_larsson@yahoo.com> wrote:
Hi all!
Best,
Nicklas
