[GRASS-dev] Question regarding GRASS_NOTIFY
Hi Devs,
Is there anyone out there who know about usage of the environment variable GRASS_NOTIFY, historically and in the present?
In addressing an otherwise trivial compiler warning, I stumbled into this for me strange piece of code and usage of GRASS_NOTIFY in the Raster Display Library. I put up a PR [1] suggesting the removal of this, but I agree with Vaclav I’d better ask here on the ML.
The only use of GRASS_NOTIFY is in “D_close_driver()” [2] and the value of that env variable (if set) is directly inserted in a “system()” call, without any sanitation!
Furthermore, GRASS_NOTIFY is not documented [3] other than very briefly in API docs [4].
There is a note, dated 2009, suggesting its use with ximgview [5].
I’d love to hear of your thoughts, experiences on this.
Best,
Nicklas
[1] https://github.com/OSGeo/grass/pull/2135
[2] https://github.com/OSGeo/grass/blob/28a86c92761bdeeba199fc7e2ee159f018b6d529/lib/display/r_raster.c#L164
[3] https://grass.osgeo.org/grass80/manuals/variables.html
[4] https://grass.osgeo.org/programming8/defs_2display_8h.html#ab0d0949ed77467d353a47bef17b97318
[5] https://lists.osgeo.org/pipermail/grass-dev/2009-December/047194.html
It's an external interface; it isn't used internally.
The intention is described in the email you cited: to allow a program
(specifically, ximgview or similar) to be notified of any changes to
the image file generated by the display library. It isn't required by
the GUI because the GUI can assume that the image will only be
modified by d.* commands which the GUI itself runs, so it can refresh
the view upon their completion.
The idea was to support the use of d.* commands from a shell,
providing something similar to the "monitor" system that was being
replaced at the time. I've have no idea whether such usage is still
common or even officially supported (but scripts/wxpyimgview is still
there).
What sort of "sanitisation" would you suggest? The variable is set by
the user, its value is passed directly to the shell.
there).
I personally never had the need for the use of GRASS in this way, so forgive
my ignorance in this regard.
However, one thing stands out very clear from my newly gained experience:
there is a lack of documentation on this use of GRASS_NOTIFY. For instance,
it is not clear to me is whether it is required or optional to set GRASS_NOTIFY
with e.g.:
export "GRASS_NOTIFY=kill -USR1 `pidof ximgview`”
for this to work as intended. Surely it is not expected a user should look for this
information in the mailing list.
I’d say it would be better to avoid sanitation, with what I mean making sure
GRASS_NOTIFY hasn’t been compromised, at all. Couldn’t the desired outcome
of using GRASS_NOTIFY be implemented in another way?
(It could, probably rightfully, be argued that this is not the single one weakness in
GRASS code and in addition a very unlikely attack vector, but why leave doors
open if not needed).
with e.g.:
I think that it's "expected" that the user will just use the GUI.
It seems doubtful that anyone (other than me) actually used this. I no
longer actively follow GRASS; I only remained subscribed to the list
for cases (like this) where someone is asking about arcane details of
stuff I worked on in the past.
Well, it could be made a GRASS ($GISRC) variable. A fixed command name
could be inconvenient if you have multiple GRASS sessions in different
shells (again, I don't think this is "typical" user behaviour). It
could use some other mechanism entirely (e.g. a filename identifying a
socket or named pipe to which D_close_driver would write) would work,
but would be a non-trivial effort for something that probably isn't
even used.
I'm not sure manipulating GRASS_NOTIFY gets you much compared to
manipulating e.g. EDITOR or BROWSER. And unless there's been a
significant effort on security since I was active, using GRASS with
untrusted inputs or an untrusted environment has much bigger issues.
In any case, ximgview/wxpyimgview don't appear to have had any
substantial changes or issues (i.e. nothing that doesn't appear to be
a repository-wide clean-up) in the last decade, so non-GUI usage of
the display subsystem is probably a non-issue at this point.
On Fri, 4 Mar 2022 at 10:09, Nicklas Larsson via grass-dev <grass-dev@lists.osgeo.org> wrote:
The purpose was interactive use from the command line I suppose, so for these cases users can set a convenient alias for sending the signal or a prefix command to use with the display commands (to call the command and then send the signal) like ni d.rast elevation where ni is the command/alias. Adding something similar to a script has even a smaller overhead, although it too requires you making sure it happens every time instead of the one-time GRASS_NOTIFY settings. (I’m assuming here that signal handling in the imgview programs is not removed.)
I have finally had the time to take a little better look at the code and actually test
ximgview/wxpyimgview. I replaced my first PR [1] for deleting GRASS_NOTIFY
with a PR [2] with which a G_warning is issued if the system call fails.
The documentation on using ximgview/wxpyimgview, including the signal handling,
could probably be improved. I will at least file a ticket with that aim.
Thank you Glynn for jumping in on this, I very much appreciate it!
[2] https://github.com/OSGeo/grass/pull/2705
with e.g.:
even used.
