[GRASS-dev] r.colors "-e" not going to full range
I just created a v.surf.rst elevation surface from some point data which
has a few negative values in it. After creating the surface I set the
colors with 'r.colors -e color=bcyr'. It looks really nice but there are
white holes in the d.rast display.
r.info -r shows:
min=-1.510814
max=146.157700
The colr/ file doesn't go to one integer beyond the full range:
% -1 145
nv:255
*:255
-1:0:0:255 0:0:94:255
144:255:1:0 145:255:1:0
I also noticed for another map 'r.colors -e' made a massive and slow
colr/ file (1 for each cat) when the raster values were +-250000. That
was a diff map centered on zero and I was using r.colors.stddev (wiki
addons) to set the colors. While it had those huge outliers 95% of the
points were +-5 (hence using the -e flag to get useful colors). It took
impossibly long to render of course, so I looked in the colr/ file and
discovered it was huge.
Ok, maybe that's a feature of the -e method. But what I saw that was
interesting was that between -265000 and -120 all the R:G:B values were
identical, ie all those thousands and thousands of rules could have been
condensed into a single "-265000:R:G:B -120:R:G:B". And that a little
program to do that would probably be trivial. I am a bit unsure if that
condensing should happen as a addon script which reprocesses the file,
when the colr/ file is created by 'r.colors -e', or when the color rules
are read in upon d.rast. (or some combination of the above) It would seem like a nice enhancement to have that happen though.
I notice that even in my current -1.5 thru 146m map '-e' produces some redundant entries.
Hamish
r.info -r shows:
min=-1.510814
max=146.157700
% -1 145
nv:255
*:255
I didn't realise that "r.colors -e" even worked on FP data;
"r.colors color=grey.eq" doesn't.
Ultimately, the code is dependent upon the categories returned by
G_next_cell_stat(). If it only returns up to category 145, then the
colour table will only extend to that value.
Can you test the attached patch?
(attachments)
color_xform.c.diff (1.35 KB)
> which has a few negative values in it. After creating the surface I
> set the colors with 'r.colors -e color=bcyr'. It looks really nice
> but there are white holes in the d.rast display.
> r.info -r shows:
> min=-1.510814
> max=146.157700
> % -1 145
> nv:255
> *:255
Glynn:
> min=-1.510814
> max=146.157700
> % -1 145
I could assume the -1.51 -> -1 problem was due to a cast to CELL when
using a FP map with "*_cell_stat". The 146.15 vs 145 is a bit weirder,
cast + missing the last iteration? No idea how to make it extend to be
"% -2 147" for FP maps with G_next_cell_stat().
> took impossibly long to render of course, so I looked in the colr/
> file and discovered it was huge.
> were identical, ie all those thousands and thousands of rules could
> have been condensed into a single "-265000:R:G:B -120:R:G:B". And
> that a little program to do that would probably be trivial. I am a
> bit unsure if that condensing should happen as a addon script which
> reprocesses the file, when the colr/ file is created by 'r.colors
> -e', or when the color rules are read in upon d.rast. (or some
for a random lidar test map, the colr/ file is 21349 lines long unpatched
and 1497 lines long patched. Nice. There is still room for improvement
though:
[color_xform.c unpatched]
% -14900 1462400
nv:255
*:255
-14900:0:0:255 -14100:0:0:255
-14100:0:0:255 -14000:0:0:255
-14000:0:0:255 -13800:0:0:255
-13800:0:0:255 -13700:0:0:255
-13700:0:0:255 -13600:0:0:255
-13600:0:0:255 -13400:0:0:255
-13400:0:0:255 -13300:0:0:255
-13300:0:0:255 -13200:0:0:255
-13200:0:0:255 -13100:0:0:255
-13100:0:0:255 -13000:0:0:255
-13000:0:0:255 -12900:0:0:255
[color_xform.c patched]
% -14900 1462400
nv:255
*:25
-14900:0:0:255 -10500:0:0:255
-10500:0:0:255 -10400:0:1:255
-10400:0:1:255 -9800:0:1:255
-9800:0:1:255 -9750:0:2:255
-9750:0:2:255 -9350:0:2:255
-9350:0:2:255 -9300:0:3:255
-9300:0:3:255 -9000:0:3:255
-9000:0:3:255 -8950:0:4:255
-8950:0:4:255 -8700:0:4:255
-8700:0:4:255 -8650:0:5:255
-8650:0:5:255 -8450:0:5:255
-8450:0:5:255 -8400:0:6:255
-8400:0:6:255 -8300:0:6:255
-8300:0:6:255 -8200:0:7:255
-8200:0:7:255 -8050:0:7:255
-8050:0:7:255 -8000:0:8:255
-8000:0:8:255 -7900:0:8:255
-7900:0:8:255 -7850:0:9:255
-7850:0:9:255 -7700:0:9:255
it seems that every second line is redundant.
aside: I hadn't noticed the *:color [undefined, does this correspond to
"default" in G_parse_color_rule()?], invert, and shift:n colr/ rules
abilities before. invert is now covered by the r.colors -n flag using
another method, is 'shift' of any use?
Hamish
Hamish wrote:
['r.colors -e color=bcyr' for a FP map]
% -14900 1462400
nv:255
*:25
actually, it has made long series of steady color followed by the color
transition all occurring in a sudden step?
(I said this was LIDAR elevation data, actually it is elev*10000. as
r.surf.idw,.idw2,... only output CELL maps, I was r.mapcalc'ing the
result back to FP)
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> > r.info -r shows:
> > min=-1.510814
> > max=146.157700
> > % -1 145
> > nv:255
> > *:255
Glynn:
> > min=-1.510814
> > max=146.157700
> > % -1 145
It's more complex than a simple cast. For computing statistics,
r.colors reads the map as CELL (as that's all that Cell_stats
supports). The map will be converted using G_quant_get_cell_value()
(lib/gis/quant.c).
though:
% -14900 1462400
nv:255
*:255
% -14900 1462400
nv:255
*:25
In this case, yes, as only one component changes at each step, and
only changes by one. If the colour table has any discontinuities,
eliminating the flat sections would make a significant difference.
Ultimately, this should still be an improvement over the previous
output. For now, I'm more concerned with it being right than getting
further efficiency.
Yes.
invert, and shift:n colr/ rules abilities before. invert is now
covered by the r.colors -n flag using another method,
This is what r.colors -n uses. It calls G_invert_colors(), which
inverts the "invert" field in the Colors structure, which corresponds
to the "invert" keyword in the file.
I don't know. If it's present, all values are shifted by this amount
and (if necessary) wrapped into the range of the colour table before
they are looked up.
