[GRASS-dev] r.colors.matplotlib
Hello Vaclav,
Thanks for writing the r.colors.matplotlib tools because I use the matplotlib colorramps very frequently both in GRASS and in python more generally.
I seem to be having a problem of using the perceptually uniform ramps in the r.colors.matplotlib add on, receiving the error: ERROR: Matplotlib 2.0.2 does not contain color table
I’m on linux and matplotlib 2.0.2 has the perceptually uniform ramps, and I can use them if I display data in python within a GRASS session directly (i.e. plt.imshow(numpyraster, cmap=‘plasma’).
Is there a reason why r.colors.matplotlib can’t see these ramps? It still works with all of the traditional matplotlib ramps.
Steve
Hi Steve,
On Tue, May 30, 2017 at 3:10 PM, Steven Pawley <dr.stevenpawley@gmail.com>
generally.
Glad to hear that.
2.0.2 does not contain color table <plasma>
I'm on linux and matplotlib 2.0.2 has the perceptually uniform ramps, and
(i.e. plt.imshow(numpyraster, cmap='plasma').
Is there a reason why r.colors.matplotlib can't see these ramps? It still
The module does not check for specific color maps in mpl, but it uses
general code to check the presence of a requested color map. It imports
matplotlib.cm.datad dictionary. Perhaps, this dictionary does not contain
the new color maps. The checking is not ideal, it should based on
cm.get_map() function. I think the reason why I "ask for permission" here
instead is that I was not able to figure out what is the error state from
get_map() or how to transfer it to the user. But perhaps you will be more
successful or 2.0 behaves differently. The relevant code is here:
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.colors.matplotlib/r.colors.matplotlib.py#L164
Best,
Vaclav
Thanks Vaclav,
Will see if I can figure out.
Steve
On Thu, Jun 1, 2017 at 8:51 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Hi Steve,
On Tue, May 30, 2017 at 3:10 PM, Steven Pawley <dr.stevenpawley@gmail.com> wrote:
Glad to hear that.
The module does not check for specific color maps in mpl, but it uses general code to check the presence of a requested color map. It imports matplotlib.cm.datad dictionary. Perhaps, this dictionary does not contain the new color maps. The checking is not ideal, it should based on cm.get_map() function. I think the reason why I “ask for permission” here instead is that I was not able to figure out what is the error state from get_map() or how to transfer it to the user. But perhaps you will be more successful or 2.0 behaves differently. The relevant code is here:
Best,
Vaclav
