[GRASS-dev] r.colors.out_sld problems installing and running
Hi Hamish
I am trying to install your r.colors.out_sld plugin using g.extension, but I am getting the following error message:
Compiling...
/tmp/grass7-paulo-7909/tmpBesVaZ/r.colors.out_sld/docs/html/r.colors.out_sld.html:73:0: Error (IndexError('pop from empty list',)): export of contious color rules (ramp).</p>
make: *** [/tmp/grass7-paulo-7909/tmpBesVaZ/r.colors.out_sld/docs/man/man1/r.colors.out_sld.1] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
This looks like it might be an issue with the html page, which does not seem to follow the guidelines. Attached a patch file (r.colors.out_sld_html.patch) with some changes to comply with the guidelines, which perhaps solves above.
After copying the script to the script folder, the plugin runs fine for maps with categories, but gives an error for raster layers without categories. The attached patch (r.colors.out_sld.patch) corrects this I hope.
Best wishes,
Paulo
(attachments)
r.colors.out_sld.patch (736 Bytes)
r.colors.out_sld_html.patch (1.66 KB)
On 21 December 2016 at 16:37, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Hi Hamish
Compiling...
(ramp).</p>
make: ***
Error 1
yes I got the same errors, I applied bot patches.
Thanks a lot
Best wishes,
Paulo
ciao
Luca
www.lucadelu.org
