[GRASS-dev] r.cpt2grass - add option to multiply values
Hi Anna
Just an idea I got when using r.ctp2grass for some climate data. Climate data layers are often multiplied by a factor 10 so they can be distributed as integer rasters while still maintaining a desired degree of precision. This made me think that it would be nice if I could create a color rules file using r.ctp2grass with the option to multiply the default values as defined in the ctp file. Perhaps something along the lines of attached patch file for r.ctp2grass (for illustrative purposes, I am sure things can be done better)? Is that something that could be implemented? Something similar could perhaps be nice for r.colors as well when using one of the included color tables (but only those based on values rather than percentages obviously).
Paulo
(attachments)
add multiply option to cpt2grass.patch (1.11 KB)
Hi Paulo,
On Tue, Dec 1, 2015 at 10:17 AM, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Hi Anna
Paulo
I can’t really judge the usefulness of such option, but if you find it useful, then go ahead and commit it. I would just use ‘multiply’ or ‘multiplier’, not ‘multi’ as the option name.
Best,
Anna
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Anna, I have been rethinking this option, and it is probably something that is too specific. For linear scales, the -s flag will be sufficient, while other color scales will often be tailored to specific cases anyway.
On 12-12-15 04:21, Anna Petrášová wrote:
Hi Paulo,
Hi Anna
Paulo
Best,
Anna
