Hi devs,
I found a strange r.cross behaviour, the output includes a random 0 category without any label information. Here an example in the NC sample location:
g.version -rg
> version=7.0.0
> date=2015
> revision=00000
> build_date=2015-01-24
> build_platform=x86_64-unknown-linux-gnu
> libgis_revision=64007
> libgis_date="2015-01-08 20:08:36 +0100 (Thu, 08 Jan 2015) "
# set region so that all maps have non-NULL values
g.region n=224470 s=219020 w=633040 e=640160
r.cross basins,landuse,soils out=test__
r.mapcalc exp='test__0=if(test__==0)'
r.stats test__0 -c
> 0 335445
> 1 189
These 0 areas change when the region is changed or a mask is applied. The only correlation with the input data I could find was the fact that one of them always seems to have the category 1 in these areas. That seems like an inconsistent behaviour and annoying if you expect non-zero output or rely on the label information of the output.
Best regards,
Michel
