[GRASS-dev] r.describe "Range" output report type - superseded?
The docs for r.describe mention two kinds of reports that can be selected for output. I
can't find any evidence of this by experimenting with the module. Specifically, the docs mention
that a 'range' report can be generated, where negative min/max, zero, and positive min/max values are reported, and
a 'Full List' report (which seems to be the program default output). Is the former just old
relic behavior that has been superseded and not updated in the docs? I wanted to be sure before
scrapping it from the manpage. I can't seem to get the program to output values the way this report mode is described.
~ Eric.
excuse me if I a miss something but I get (GRASS6.2.2 & 6.3)
r.describe SRTM3
READING [SRTM3 in nik] ... 100%
* -15 -13 -12 -10 thru 2285 2287-2314 2316-2318 2320-2325 2327-2330 2334
2342
2344 2347 2349 2350 2357 2358 2361 2365 2375
and
r.describe -r SRTM3
-15 thru -1
0
1 thru 2375
You're right, the range is output is only printed with the -r flag. I think I was trying to
reproduce the same behavior without using the flag, and was getting confused in the process.
I'll update the docs accordingly. Thanks,
~ Eric.
