I have discovered an undocumented feature (?) in r.distance.
The manual reads:
r.distance maps=map1,map2
When I specify it as:
r.distance maps=map1 maps=map2
it works as well.
The order can also be controlled this way. I.e.:
r.distance maps=map1,map2 is equivalent to r.distance maps=map1 maps=map2
and:
r.distance maps=map2,map1 is equivalent to r.distance maps=map2 maps=map1
Can I rely on this behavior or may it change in future? Currently it works for 6.4 svn and 7 svn.
Maciek
Maciej Sieczka
http://www.sieczka.org
W dniu 11.11.2010 18:22, Maciej Sieczka pisze:
The manual reads:
it works as well.
and:
I'm asking this because the 'maps=map1 maps=map2' syntax would let me add the command to QGIS GRASS toolbox - now. Otherwise, it would require adding support for 'maps=map1,map2' syntax - unknown if/when would be implemented.
Maciek
Maciej Sieczka
The manual reads:
it works as well.
This is a feature of the parser, and works for all modules.
and:
It isn't expected to change. It's useful for constructing argument
lists using xargs, e.g.:
... | sed 's/^/map=/' | xargs g.something ...
This is much harder to achieve using the opt=val,val,val,... syntax.
