I just tried to install the r.diversity addon in GRASS 7, but it doesn’t seem to work. Are there any plans to port this in the near future to GRASS 7? I had a look myself, but my Python skills are too limited.
Rgds
Paulo
Rgds
Paulo
Hi Paulo,
(cc Luca)
On Sun, Jan 5, 2014 at 10:50 PM, Paulo van Breugel
<p.vanbreugel@gmail.com> wrote:
I just tried to install the r.diversity addon in GRASS 7, but it doesn't
Done in r58619 (easy since it was already written in Python) and r58621.
You may try with g.extension to install and use it but I think it
needs a bit more finetuning (I didn't get the examples running yet,
but it will be rather easy for a Python programmer).
Hi Markus,
Thanks, I was able to install it. Running it gave me the error :
File "/home/paulo/.grass7/addons/scripts/r.diversity",
line 284, in <module>
sys.exit(main())
line 139, in main
checkAlpha(methods,alpha_value)
UnboundLocalError: local variable 'alpha_value' referenced
before assignment
After filling in an alpha value (1) it runs but I get the next error message (but the alpha value should be optional, right?):
ERROR: Cannot find configuration file </home/paulo/.grass7/r.li/conf_diversity_3.0>
[1.0]
All works are terminated
Indeed, in the given folder there is not such conf file.
Paulo
On Mon 06 Jan 2014 12:57:28 AM CET, Markus Neteler wrote:
Hi Paulo,
(cc Luca)On Sun, Jan 5, 2014 at 10:50 PM, Paulo van Breugel
<p.vanbreugel@gmail.com> wrote:Hi,
7? I had a look myself, but my Python skills are too limited.Done in r58619 (easy since it was already written in Python) and r58621.
but it will be rather easy for a Python programmer).Markus
On 6 January 2014 11:13, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Hi Markus,
Hi
sys.exit(main())
line 139, in main
before assignment
thanks, you discovered a bug
Fixed
it is not optional if you use the renyi and by default all methods are
used (before it was not specify, now yes
[1.0]
All works are terminatedIndeed, in the given folder there is not such conf file.
yes, because the directory change from grass6 to grass7, fixed.
Now it should work, please try 58632
Paulo
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Hi Luca
Great, thanks!
I just tried to run the function, but initially got the error:
ERROR: Reading raster map <ANN_MOD14A2_2002_L1_count@Fire> request for row 68 is outside region
This was with a region smalller than the input map. After setting the region to cover the whole map, the function ran without problems. Which brings me to the question, does the function (or the underlying r.li) not respect the region settings or is this a bug?
Paulo
Hi Markus,
Hi
sys.exit(main())
line 139, in main
before assignmentthanks, you discovered a bug
FixedAfter filling in an alpha value (1) it runs but I get the next error message
(but the alpha value should be optional, right?):it is not optional if you use the renyi and by default all methods are
used (before it was not specify, now yesERROR: Cannot find configuration file
[1.0]
Paulo
On 7 January 2014 07:35, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Hi Luca
Hi Paulo
Great, thanks!
68 is outside regionThis was with a region smalller than the input map. After setting the region
I think this is a bug of r.li modules in GRASS7.
I try to create the same configuration file with GRASS7 and GRASS6 and
they are identical but in GRASS6 I don't obtain any error instead in
GRASS7 I obtain your same error.
I'm going to open a ticket in the next hours/days.
Thanks
Paulo
ciao
Luca
www.lucadelu.org
OK, thanks
Hi Luca
Hi Paulo
Great, thanks!
region settings or is this a bug?I think this is a bug of r.li modules in GRASS7.
GRASS7 I obtain your same error.I'm going to open a ticket in the next hours/days.
Thanks
Paulo
On 8 January 2014 11:41, Luca Delucchi <lucadeluge@gmail.com> wrote:
Hi Paulo
Hi Devs,
I was wrong, also GRASS6 has the same problem (maybe in GRASS6 is
worst because it continue to print the message for all row outside
region)
I open a new thread/ticket
Thanks
ciao
Luca
www.lucadelu.org
Please try first the patch
http://trac.osgeo.org/grass/ticket/2024
r_li_bug_2024.diff (15.9 KB) - added by rashadkm 2 weeks ago.r.li.* fixes
test it....
the patch probably fix other problems
ciao
Luca
www.lucadelu.org
