In working with r.drain to create a least-cost path map, it seems that the -c flag creates a path with cumulative values, but not one that I can see is usable for anything.
What happens now is that starting at the beginning of the path, each cell adds the underlying cost surface (or elevation for a drainage map) value to the value of the preceding cell in the path. At the end, the last cell has a value of the sum of all the cost (or elevation) values between the start and the end. So for a path traversing cells of the following values...
300 | 200 | 100 | 0
The path cells would have the values...
300 | 500 | 600 | 600
This is indeed a cumulative cost, but not one that is useful for anything I can think of. What would be much more useful if each cell calculated the difference between the current cost value and the preceding one and added that to the preceding path value. For the cost surface above, the result would be...
0 | 100 | 200 | 300
This gives the actual cost of traversing the path at any point along the path and the total cost at the end. Note that this is different than just copying the underlying cost value into the path if the path is not a straight line.
Any interest in changing the behavior of -c or maybe making a -t (total) flag?
Michael
______________________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
