[GRASS-dev] r.fill.dir segfaults on large maps.
I’m using r.fill.dir on a very large landscape, and noticed that it will segfault if the number of cells is > 150,000,000. Is this a known limitation of r.fill.dir, or a bug? Happy to report the bug if so. I’m using latest nightly of GRASS 7 on Ubuntu 14.04.
Isaac I Ullah, Ph.D.
Arizona State University
PO Box 2402
Tempe, AZ 85287-2402
(480) 727-1054 office
(650) 201-0479 cell
iullah@asu.edu
On Thu, Feb 11, 2016 at 5:43 PM, Isaac Ullah <isaac.ullah@asu.edu> wrote:
   I'm using r.fill.dir on a very large landscape, and noticed that it
limitation of r.fill.dir, or a bug? Happy to report the bug if so. I'm
Might be a memory issue. If you don't have enough memory, it would give you
an error that it can't allocate. Is this perhaps the case? If not, then
it's probably a bug.
Anna
PO Box 2402
(650) 201-0479 cell
iullah@asu.edu
grass-dev mailing list
grass-dev@lists.osgeo.org
Hmmm… I restarted GRASS and I can no longer replicate the problem. It was a very specific cut-off at 150 million cells though. I guess it’s a non-issue since it works now. I monitored the memory usage, and even at 400 million cells, it was only using 52 MB. Strange why it was breaking before! Thanks for your help though.
~Isaac
On Thu, Feb 11, 2016 at 4:26 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
Might be a memory issue. If you don’t have enough memory, it would give you an error that it can’t allocate. Is this perhaps the case? If not, then it’s probably a bug.
Anna
PO Box 2402
(650) 201-0479 cell
iullah@asu.edu
PO Box 2402
(650) 201-0479 cell
iullah@asu.edu
