[GRASS-dev] r.forestfrag
I was trying to run r.forestfrag.sh on GRASS 7.0. It is incompatible however, so I decided to update it to work with GRASS 7.0.
While working on it, I have added some further options and changes:
  • The user can now select the size of the moving window (default is still 3x3) – Stefan, something you were looking for I think. Perhaps you can test?
  • Before the areas statistics (r.report) is run, the output map is trimmed to remove the edge effect of the calculations with the moving window
  • The user can decide to keep the output map trimmed or not
  • The user has the option to keep some of the intermediate layers (off by default).
    I have added the new version of r.forestfrag.sh to https://svn.osgeo.org/grass/grass-addons/grass7/raster/r.forestfrag/ to make it easer for other to check / correct the script. It doesn’t run on GRASS 6.4 unfortunately, although it should be fairly easy to make it so.
Paulo
p.s. while working on this, I ran into the problem that g.parser seems to parse the GUI window differently when running from the command line or from the command console in the GRASS Layer Manager (as reported here: http://trac.osgeo.org/grass/ticket/1858)
