[GRASS-dev] r.in.ascii strangeness
I’ve attached a simple text file that I read into GRASS with r.in.ascii.
r.in.ascii -f input=/Users/cmbarton/Desktop/landuse_stats_all_models_orig2.txt output=landuse2 --overwrite
(I’ve tried it with -d, -ifd, and no flags)
It imports fine with no errors. It displays fine.
r.info shows that it contains data…
N: 40 S: 1 Res: 0.975 |
| E: 50 W: 1 Res: 0.98 |
| Range of data: min = 0.000000 max = 24055.437500
YET…
If I query ANY cell with r.what, I get…
23.979253112|12.2468879668||*
ALL are null. And it won’t display in NVIZ–probably because all cells are null.
r.mapcalc ‘newmap=1.0*landscape2’
produces an empty map.
I’ve run r.nulls with no effects.
Anyone have an idea what is wrong?
Michael
(attachments)
landuse_stats_all_models_orig2.txt (18.4 KB)
Michael Barton wrote:
I've attached a simple text file that I read into GRASS with r.in.ascii.
(I've tried it with -d, -ifd, and no flags)
r.info shows that it contains data...
         N: 40 S: 1 Res:
0.975 |
  | E: 50 W: 1 Res:
0.98 |
  | Range of data: min = 0.000000 max = 24055.437500
| Range of data: min = 0.000000 max = 24055.437500 |
YET...
If I query ANY cell with r.what, I get...
ALL are null. And it won't display in NVIZ--probably because all cells
are null.
r.mapcalc 'newmap=1.0*landscape2'
I've run r.nulls with no effects.
Did you set the region to match the map?
If I set the region to the map (g.region rast=test), I can't reproduce
the problem.
Also, get a decent mail program. One that doesn't insist upon
reformatting stuff that's pasted from a terminal, and doesn't stick
the attachment in the HTML part of a multipart/alternative block.
Apple's mail software has historically been bad at compatibility with
non-Apple systems (much worse than Microsoft), and they appear to
still have some way to go.
        N: 40 S: 1 Res:
0.975 |
| E: 50 W: 1 Res:
0.98 |
YET...
are null.
Yes.
the problem.
Looks like v.in.ascii imports this file just fine on a Windows system, but doesn't on my Mac. Haven't had a chance to check it under Linux, myself, but your test suggests that it is Mac specific.
Michael
Tried to import your file on a mac into spearfish location.
Have the same problem you report. But r.stats shows that the data are there.
So I tried to do a d.what.rast on the landuse map that shippes with
spearfish, where I do see data and know I should get a number. but
same here. I get novalues even if i click on a color zone.
No idea about what is going on.
>> r.in.ascii.
>> N: 40 S: 1 Res:
>> 0.975 |
>> | E: 50 W: 1 Res:
>> 0.98 |
> | N: 40 S: 1 Res:
> 0.975 |
> | E: 50 W: 1 Res:
> 0.98 |
> 24055.437500 |
>> YET...
>> cells
>> are null.
Yes.
> the problem.
Michael
grass-dev mailing list
grass-dev@lists.osgeo.org
