On Tue, Oct 16, 2007 at 04:28:32PM +0200, Markus Neteler wrote:
On Tue, Oct 16, 2007 at 04:03:31PM +0200, Kirk Wythers wrote:
> I must have missed the change in r.in.gdal where the required paramter
> "output" was droped and replaced with "group".
Kirk,
the parser was updated
Forgot to mention that this is a good thing:
We add macros there (they are now almost complete) to
facilitate the programming of the parser interface. Eg.:
input = G_define_option();
input->key = "input";
input->type = TYPE_STRING;
input->required = YES;
input->multiple = NO;
input->gisprompt = "old,dig,vector";
input->description = "vector input file";
was simplified to
input = G_define_standard_option(G_OPT_V_INPUT);
(as defined in lib/gis/parser.c).
Additional positive side effects:
- standardized wording
- messages translated to other languages in one place only
Only, which each change in lib/gis/parser.c, a full recompilation
after "make distclean" is needed to avoid shifted parameters
as you have seen.
Hope this clarifies it.
PS: list of currently predefined macros:
G_OPT_WHERE, /* SQL where conditions */
G_OPT_TABLE, /* table name */
G_OPT_DRIVER, /* driver name */
G_OPT_DATABASE, /* database name */
G_OPT_COLUMN, /* one attr column */
G_OPT_COLUMNS, /* one or more attr columns */
G_OPT_I_GROUP, /* old input imagery group */
G_OPT_R_INPUT, /* old input raster map */
G_OPT_R_INPUTS, /* old input raster maps */
G_OPT_R_OUTPUT, /* new output raster map */
G_OPT_R_MAP, /* old input raster map */
G_OPT_R_MAPS, /* old input rasters map */
G_OPT_R_BASE, /* old input base raster map */
G_OPT_R_COVER, /* old input cover raster map */
G_OPT_R_ELEV, /* old input elevation raster map */
G_OPT_R_ELEVS, /* old input elevation raster maps */
G_OPT_R3_INPUT, /* old input raster3d map */
G_OPT_R3_INPUTS, /* old input raster3d maps */
G_OPT_R3_OUTPUT, /* new output raster3d map */
G_OPT_R3_MAP, /* old input raster3d map */
G_OPT_R3_MAPS, /* old input raster3d maps */
G_OPT_V_INPUT, /* old input vector map */
G_OPT_V_INPUTS, /* old input vector maps */
G_OPT_V_OUTPUT, /* new output vector map */
G_OPT_V_MAP, /* old input vector map */
G_OPT_V_MAPS, /* old input vector maps */
G_OPT_V_TYPE, /* primitive type */
G_OPT_V_FIELD, /* field number */
G_OPT_V_CAT, /* one category */
G_OPT_V_CATS, /* more categories */
G_OPT_F_INPUT, /* old input file */
G_OPT_F_OUTPUT, /* new output file */
G_OPT_F_SEP, /* data field separator */
G_OPT_C_FG, /* foreground color */
G_OPT_C_BG /* background color */
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
